Username Post: 1948 rear shocks        (Topic#363347)
turfman454
Reg: 10-04-05
11-20-20 03:04 PM - Post#2808178
need to replace the rear shocks on my 48 coupe with a chassis engineering rear leaf spring kit. Mine are 25 years old and CE is now owned by heidts and they cannot cross reference the shocks they used. Emailed both Monroe and Gabriel and they cant identify them.
lofat46
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
11-20-20 04:15 PM - Post#2808179
    In response to turfman454
I had the CE kit on my ‘46 Chevy. Seem to recall hearing the shocks were from a ‘62 Chevy 1/2 ton pick up. You should be able to find a guide that gives the fully closed and extended dimensions of similar shocks.
Edited by lofat46 on 11-20-20 04:17 PM. Reason for edit: No reason given.
turfman454
Reg: 10-04-05
11-21-20 08:48 AM - Post#2808236
    In response to lofat46
than ks Heidts did think it may be a 61 dodge pickup. they are going to research it and see what they come up with. Thanks for the reply
Broo102
Broo102
Loc: Huntington Beach, CA.
Reg: 09-30-14
11-23-20 04:33 PM - Post#2808446
Call Poseys, thats where i got my leafs for my 47
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
Jack Crain
Loc: Wichita Falls, Texas
Reg: 07-24-11
11-28-20 03:03 PM - Post#2808873
    In response to Broo102
I got a set for my 46 and I believe Lofat is right. I wanted to put air shocks on my 46 and called em up to ask what shock they used. But, he advised against the air shock be cause the mounts wouldn't hold the weight of the car. But I do remember it was a 60's Chevy pickup shock.
1946 Fleetmaster 4-dr Sedan with '57 235
Fenton Dual Exhaust and Intake
Dual Carter Webbers 2 barrel Carbs
HEI ignition
Front Disk Brake
T-5 Tranny
55MAS
Loc: North Coast, USA
Reg: 12-19-01
11-29-20 06:50 AM - Post#2808938
Remove a shock and post some physical information: End mount style on both the top and bottom, as well as the center-to-center measurement of the shock end mounts both fully collapsed and fully extended.
Execution time: 0.278 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:08 PM
