Username Post: 03 astro van P0175 code        (Topic#363202)
fitter
Loc: saint louis missouri
Reg: 09-27-03
11-08-20 07:26 AM - Post#2807240
225k runs good. The only thing found is fuel pressure running 80 lbs. Since fuel pressure regulator is under the intake is there a downside of a external bypass regulator capping off return line from intake. This one 58lbs static pressure.
https://www.ebay.com/itm/C5-Corvette-Fuel- Pressure...
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
11-08-20 06:16 PM - Post#2807300
    In response to fitter
Removing the top of the intake manifold to replace the fuel pressure regulator isn't that difficult.
There are specific tests in the FSM to confirm the regulator is at fault.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Edited by paulo57509 on 11-08-20 06:23 PM. Reason for edit: No reason given.
11-09-20 08:08 AM - Post#2807336
    In response to paulo57509
Wow! The pressure is really high. Removing the upper plastic intake is not hard.
Four hour job for a DYI mechanic.
Check it out: https://www.youtube.com/watch?v=cdmnsd_WcDw
'08 GMC Acadia 3.6L SLE
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
11-09-20 03:06 PM - Post#2807366
4 hours??? 1 hour max...1.5 with adult beverages.
U.S.C.G. "So others may live"
'96 S-10 SS
'02 BlaZeR2
11-10-20 04:11 AM - Post#2807387
    In response to SleeperSS
Well, the video was being recorded. I'm with you. 1 hour max, extra time for BEvERageS.
I've done two. My '95 CPI and '96 MPFI upgrade. Wish I still had my '96. :smile :
Execution time: 0.156 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:14 AM
