Username Post: 84 corvette fuel pump install?        (Topic#363189)
Willow
Reg: 05-25-12
11-06-20 07:42 PM - Post#2807148
Greetings All: need to replace fuel pump in my 1984 Vette. Was told fairly easy since you can do without dropping the tank. Question please; look on utube at videos and they show guy replacing a black insulator sock as he called it, not the bottom filter screen, but slid over the pump housing. Bought new pump, Delphi brand #FE0115. No so-called insulator sock included. Called parts store, they check 3 different brands and none showing this part. Is it possible I don’t need this and should install as is? Not sure if my Vette has this as I haven’t pulled old pump yet. If it does, should I just install on new pump or just leave off this new pump? Instructions with pump not very helpful at all. There’s also a need to splice new connection wires as don’t think this will fit the OEM plug from what I’ve been told. Was told manufacturers change connections a lot. Again, hope this is a fairly easy job?
Any advice greatly appreciated.????
Sorry for the long post.
Willow
Reg: 05-25-12
11-07-20 04:35 PM - Post#2807214
    In response to Willow
Anyone????
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-08-20 04:40 PM - Post#2807293
    In response to grumpyvette
its really not hard or time-intensive, read the linked info
Edited by grumpyvette on 11-08-20 05:35 PM. Reason for edit: No reason given.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-12-20 07:01 AM - Post#2807576
well? have you replaced the fuel pump yet???
Mel Foye
Mel Foye
Reg: 09-29-00
11-14-20 05:33 PM - Post#2807727
Hope he made sure drain hole in rubber cover was clear and cover was clean b4 he pulled it off.
Execution time: 0.395 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:26 PM
