Username Post: 3 Brake Questions        (Topic#363188)
The Senator
Loc: Chancellorsville Battlefi...
Reg: 07-04-20
11-06-20 05:04 PM - Post#2807139
1960 Belair 2 Door - Rear Drum Brakes
1.) Purchased a brake spring kit from O’Reillys, must be generic as all of the springs are the same color. It states in the service manual that the springs have unequal tensions with the black having a greater tension than the grey. Concerned that the O’Reilly kit does not include the higher tension black spring (as all of the springs in the kit are grey). Should I toss this kit and purchase one specific to the vehicle with the correct colored springs?
1. b.) the black primary spring goes on the front shoe - correct?
2.) parking brake lever - the end with the spring goes on the front shoe - right?
I took these apart awhile back, got interrupted and just want to make sure it’s going back together correctly.
My Best To All
Edited by The Senator on 11-06-20 05:04 PM. Reason for edit: No reason given.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
11-07-20 06:24 AM - Post#2807168
    In response to The Senator
Maybe this will help.
This is the right, or passenger side. Note the long shoe is in the back. This is for the parking brake application.
Griff
Attachment: brake_shoes.jpg (40.72 KB) 9 View(s)
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
11-07-20 11:19 AM - Post#2807195
I bought my brake kit from O’Reilly as well and both springs are gray. When I installed automatic brake adjusters it came with a black and gray spring and the black spring can only be installed in one place as shown in the pictures. As you can see Griff and my setup is the same with the adjusters installed. Long story short I removed the adjusters and went back to the gray springs and I can’t tell any different. I have good brakes with these springs. Lamar
Attachment: 3a.jpg (603.02 KB) 7 View(s)
Right and left rear with brake adjusters installed.
Attachment: IMG_8707.JPG (154.08 KB) 7 View(s)
Removed brake adjusters and used the gray springs.
radioheaterwsw tires
Reg: 08-24-14
11-07-20 12:29 PM - Post#2807202
    In response to PLS
I believe that 57 was the first year they used return springs with unequal value. It was to ensure that the primary shoes released first thus releasing the secondary actuating force. The primary springs were rated at 50 lbs and the secondary at 40 lbs. I believe all the replacement kits available today have the springs with equal value. I'm using the current available ones on my 57 and all seems to be working just fine.
Awhile back, I came across a NOS kit from the old days that had the correct springs. If I ever replace my front brakes, I'll probably go ahead and use these, just because.
The Senator
Reg: 07-04-20
11-08-20 06:24 PM - Post#2807301
Thanks for the responses and posting the images, good stuff that is very helpful and very much appreciated.
My Best To All!
Edited by The Senator on 11-08-20 06:25 PM. Reason for edit: No reason given.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
11-12-20 07:59 AM - Post#2807581
I got mine as a kit from CarQuest.
Apparently they still have listings for them. I'm going to go out on a limb here and say that I think GM used the same springs from 57 all the way to the 70s. The auto adjuster kit even had the bar.
Griff
2005 Yukon XL
2009 Silverado
2011 Escalade ESV
Jens
"12th Year Silver Supporting Member" & 58-60 Subject Matter Expert
Jens
Loc: Iowa.
Reg: 04-21-02
11-14-20 12:11 PM - Post#2807699
    In response to beagrizzly
I expect most of the kits sold are a generic version now. I just re-did the rear end on the project I’m working on and the spring kit came marked front and rear.
Attachment: 50414556-101B-44A2-8FB1-132FF7E9CA0C.jpeg (3.98 MB) 6 View(s)
Attachment: C2969658-DFC2-4CCF-9A0A-667244567996.jpeg (3.69 MB) 7 View(s)
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
11-16-20 01:24 PM - Post#2807881
    In response to Jens
Hey, Jens. I have been wondering if you were still around. Haven't heard much from you lately.
I'm still lurking, not doing much on the +6T, but it is always in the back of my mind. So much seems to get in the way!!
Griff
2005 Yukon XL
2009 Silverado
2011 Escalade ESV
Techhead
Techhead
Loc: Etobicoke, Canada
Reg: 10-25-05
11-17-20 10:34 AM - Post#2807944
    In response to Jens
My kit came from CARS INC and has the coloured springs.
It now sits in a box of parts that will never get used as I have gone with disks all around.
58 Delray in disaray
Jens
Jens
Loc: Iowa.
Reg: 04-21-02
11-18-20 01:07 PM - Post#2808024
Hi Griff, yes still here plugging away.. just all takes time. Good luck with your project.
Attachment: 7A59DBB8-794B-4911-93BD-EF5CBEFCAFC7.jpeg (4.09 MB) 8 View(s)
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
11-19-20 09:06 AM - Post#2808083
    In response to Jens
You're like a one-man assembly line!!
Oh, yeah. I forgot the Swiffer girls.
Griff
p.s. I have another small project that I am working on. Doesn't matter what I do when I upload it. It is rotated 90deg.
Attachment: roman.jpg (1.36 MB) 4 View(s)
2005 Yukon XL
2009 Silverado
2011 Escalade ESV
PLS
PLS
Reg: 06-07-12
11-19-20 02:11 PM - Post#2808102
My Best To All!
How about posting some pictures of the '60, we love pictures, Lamar
Looks like a wonderful addition to the family. Hopefully you can get the 6t done by the time he/she gets their license. Lamar
Attachment: griff__2_.jpg (160.32 KB) 1 View(s)
How about this.
Execution time: 0.863 seconds.   Total Queries: 23   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:27 PM
