Username Post: 1948 Fleetline needs a frame        (Topic#363090)
atomicneon
Loc: Branson, Missouri
Reg: 10-26-20
10-28-20 03:01 PM - Post#2806424
I need some help here. I stumbled across a 1948 Fleetline (2 door) body with no frame. The frame was left outside for sand blasting and powder coating and was stolen as scrap metal. That being said, they are selling just the body and it is very straight. My question is, what frames will work under this body? I was told a 4 door Fleetline frame is the same from 1942 to 1948? Are there other options...maybe modern frames? Also, I know of a 1948 Pontiac Silver Streak (2 door) for sale. It is rough shape but the frame is good. The body looks the same as the Fleetline, minus some trim. I have loved the Fleetlines for years and own a 1952, but this 1948 is a good deal. I appreciate any help. Thank you.
Andy
10-28-20 03:18 PM - Post#2806430
    In response to atomicneon
Here are the frame measurements
https://www.gmheritagecenter.com/docs/gm-heritage-...
Thought the Pontiac should be there, but cannot find it. I am not sure, but the Pontiac should be the same or very close.
29-41, 42-48, 49-54 Moderator
1946 Chevy 1/2 ton pickup, stock. Purchased 11/18/17. Sold 9/16/20
atomicneon
Reg: 10-26-20
10-28-20 03:33 PM - Post#2806434
Thank you Keith. I have compared both cars (in pictures) and they sure look the same. The only thing that looked different is the Silver Streak looks like the space between the rear of the front fender and the front of the rear fender looks shorter. But it could just be me. Thanks again.
lofat46
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
10-29-20 04:34 AM - Post#2806471
Any Chevy passenger car frame from any model from ‘41 through ‘48 will work. All have the same wheel base. The convertible frames has a heavier duty x-member, but would work. I’m not sure the Pontiac frame would work as I believe crossmembers are different to fit a different floor shape. Doesn’t the Pontiac have coil springs? If so, the cross member for the coil springs could interfere with the Chevy trunk floor. Chevy’s are far more plentiful than Pontiacs, I’d find a bare frame somewhere.
BOBDAWG
BOBDAWG
Loc: Wildomar,CA.usa
Reg: 03-01-03
10-29-20 11:39 AM - Post#2806509
Try Turners Auto Wrecking in Fresno California, They had one a couple months ago.
atomicneon
Reg: 10-26-20
10-29-20 01:57 PM - Post#2806517
    In response to lofat46
Thank you lofat46. I will begin my search. I lost a lot of my mechanical know how after a Humvee rollover in the Middle East, so I am starting from scratch. But I am going to hit this and move forward. Again, thank you for your help.
Andy.
atomicneon
Reg: 10-26-20
10-29-20 01:58 PM - Post#2806518
    In response to BOBDAWG
Thank you BOBDAWG. Unfortunately I am in Missouri.
Andy
Broo102
Broo102
Loc: Huntington Beach, CA.
Reg: 09-30-14
10-29-20 06:12 PM - Post#2806547
Jerrys 816 833 4414 in Kansas
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
atomicneon
Reg: 10-26-20
10-30-20 07:11 PM - Post#2806657
    In response to Broo102
Thank you broo102. I will give them a call. Are they a shop, a scrap yard?
Broo102
Broo102
Reg: 09-30-14
10-31-20 08:50 PM - Post#2806727
Believe hes a bone yard, if he doesnt have it, he'll know where to get it
Good luck
Bru
Thanks!
Bru
John 3:16
Edited by Broo102 on 10-31-20 08:51 PM. Reason for edit: No reason given.
atomicneon
Reg: 10-26-20
11-01-20 06:33 PM - Post#2806803
Thank you for all of the help. Here is another question. I did find a frame from a 1948 Sports Sedan (maybe it's called the Stylemaster or Fleetmaster....it has the 7 windows). I know the frame will fit, but will other body parts work on the 2 door Fleetline. Specifically the front and rear bumpers and the rear passenger fender? Is there somewhere that has a listing of what metal and glass is interchangeable among the body styles and years?
Thanks again for all of the help...I am new to all of this.
lofat46
lofat46
Reg: 08-12-13
11-01-20 08:02 PM - Post#2806814
The front and rear fenders are the same, as are the bumpers and brackets.windhsields, rear glass, front & rear window trim and inside garnish moldings, dash, and vent windows & vent regulators are the same. Trunk lid should be the same as well as the hood. The four door floors will be the same if you need patches, Gas tank too. The the rocker moldings will fit. The only things you can’t use from the four door are the doors, door glass, window regulators (shorter than two door), seats. Find yourself a Chevrolet Body Manual for 1947 or 48. I found mine on eBay, it’s the Bible for working on those cars.
Edited by lofat46 on 11-01-20 08:07 PM. Reason for edit: No reason given.
atomicneon
Reg: 10-26-20
11-01-20 09:10 PM - Post#2806820
Thank you lofat46. I have found a "1946-1948 Body Manual Service and Construction" on Ebay. This sounds like the one you are talking about.
11-03-20 06:39 PM - Post#2806949
Here is an interchange manual for GM cars.
Attachment: Interchangeable_Parts_opt.jpg (31.28 KB) 12 View(s)
atomicneon
Reg: 10-26-20
11-09-20 03:11 PM - Post#2807367
Thank you Keith. Where is the best place to get one of these? Thank you for your help.
Andy
BOBDAWG
BOBDAWG
Reg: 03-01-03
11-09-20 04:07 PM - Post#2807371
try here: www.faxonautoliterature.com
atomicneon
Reg: 10-26-20
11-10-20 06:26 PM - Post#2807427
Thank you....I found it there for $20.00.
Andy
11-10-20 07:28 PM - Post#2807437
Glad you found it. I had no idea where to get it. I got it over 35 Years ago at the Towe Museum, when it was in Deer Lodge Montana.
Execution time: 0.441 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:15 PM
