Username Post: Toe In on a 57 Chevy        (Topic#363041)
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
10-24-20 06:56 AM - Post#2806086
I'm replacing the steering arms on my 57. Also the tie rod ends (because I used a pickle fork to unloose them from the steering arms) Also new tie rod adjusting sleeves. All from a sponsor here.
Then Everything will have been replaced!
Will simply counting threads as the parts come off and reinstalling the new parts the same amount keep me in the ballpark of alignment so I can get it to the alignment shop?
I read somewhere about a long stick and checking to make sure the side to side of the rear and front of the tire measurment are the same. Will that help? Thanks
I'd rather be thorough than vague
10-24-20 01:07 PM - Post#2806109
    In response to 4dr 57
Counting threads won't work if your changing parts. It might work if your reinstalling the same parts. The long stick or tape measure is a better way to get it to the alignment shop.
Site Ambassador
10-24-20 01:17 PM - Post#2806110
The easiest and fastest way to check toe in is to point the front wheels straight (visually check to see if both look like they are both pointing straight), pick a tread to measure to (the same tread on each tire), and measure to that tread straight across as high up as you can on the front of the tire and as high up as you can on the rear of the tire. The front measurement should be slightly smaller than the rear measurement. You can also mark the tire with chalk around the circumference to give a visual reference where to take your measurement.
1957 Cameo Carrier
4dr 57
Reg: 11-10-04
10-25-20 05:31 AM - Post#2806141
    In response to acardon
Thank You Very Much acardon
4dr 57
Reg: 11-10-04
10-25-20 05:35 AM - Post#2806142
    In response to wagonman100
Thanks wagonman100 the only problem I see here is that the car is off the ground on jackstands and it sounds like this method id for a car sitting on a rack.
I will consider the method described censored workable for either application unless you think differently in which case I will resort to the stick method.
Stanley
10-25-20 05:56 AM - Post#2806144
The wheels have to be supported with the full weight of the car to measure alignment. I use ramps.
4dr 57
Reg: 11-10-04
10-25-20 02:30 PM - Post#2806178
Personally I can not wait to put these new steering arms and sleeves on after finding one shot and the other worn badly; finish up and complete my disc brake experiment, for better or worse or no change at all, and get her back on the pavement where she belongs!!
YOUNG57
Loc: Tennessee
Reg: 12-06-10
10-26-20 06:47 PM - Post#2806299
The best and most accurate way to set the (near) correct toe-in is to compare the difference between the front and rear of the two front tires. With the front tires off the ground use a pointed object to scribe a line on a flat smooth area of the tread of each front tire while rotating it to make a visible line all the way around.
Then with the weight of the car on the front tires measure the distance between the front and rear scribe lines near half the height of the tires.
With radial tires the front measurement should be 1/8” less than the rear (toe-in).
That will be close enough to get you to the alignment shop.
10-27-20 04:27 AM - Post#2806315
    In response to YOUNG57
I've done it this way for years, I use furniture movers under the tires so the suspension settles.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
10-28-20 02:38 PM - Post#2806415
Sheppard, you’re correct, I forgot. If you just set the car down on it tires, they will have hoisted angularity. I roll the car back and forward a few feet a few times for the tires to regain their normal stance before measuring toe-in.
PRL
Reg: 10-22-20
10-28-20 07:38 PM - Post#2806453
I have a similar with alignment. I put 2" dropped spindles on my 57 Belair and tried to get it aligned they said they could not set the toe-in because it did bot have adjutable A-arms. I assume I cannot put a vertical level against the tires and measure the difference at the top or bottom.
10-29-20 04:37 AM - Post#2806473
    In response to PRL
Something wrong here, toe is not set by the control arms, the steering tie rods handle this.
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
10-29-20 03:40 PM - Post#2806531
    In response to PRL
adjustable control arms and or level vertically on wheels would be measuring camber (and possibly caster to some degree...pun intended), not toe-in.
that said, on my 65 and those with a 'strut arm/rod' for caster adjustment will affect camber and toe when changed
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
Edited by docjns1 on 10-29-20 03:41 PM. Reason for edit: No reason given.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
11-02-20 06:17 AM - Post#2806832
Yes, something is wrong with that alignment guy.
Unless part of the frame was cut off and something else welded on, the upper control arms are mounted to the frame with two bolts each and adding and removing shims between the frame and the control arm pivot shaft at these bolts changes camber and caster (only, not toe-in).
Removing shims from both bolts decreases camber, moving shims from the rear bolt to the front one decreases caster.
11-02-20 06:23 AM - Post#2806833
Correct
Execution time: 0.065 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:19 AM
