chevyivar
Loc: Norway
Reg: 08-30-12
10-23-20 01:21 PM - Post#2806036
Hi.
Have been looking for a kickdown rod for a while with no luck and have desided to make my own.Do any of you guys have the lenght of the rod? Cheers
1939 Chevrolet Master Deluxe 85
1954 Chevrolet Bel Air Sport Coupe
1954 Chevrolet Bel Air Convertible |
dsacton
Loc: Boulder, CO
Reg: 11-01-11
10-26-20 04:09 PM - Post#2806277
In response to chevyivar
I'd be happy to take any measurements that I can from my '54. Can someone post a picture so I know what I am looking for? Is this on the PG side, or in the linkage?
chevyivar
Loc: Norway
Reg: 08-30-12
10-28-20 01:13 PM - Post#2806397
In response to dsacton
Hi Dsacton.
Sorry i dont know how to add pictures.. you are right, it's part of the linkage, it's the rod located on the driver side of the transmission, it connects the powerglide to the throttle linkage.Cheers:)
Edited by chevyivar on 10-28-20 01:16 PM. Reason for edit: No reason given.
dsacton
Loc: Boulder, CO
Reg: 11-01-11
10-28-20 08:26 PM - Post#2806451
Could you look through this manual and see if it is called out as something else? There are a couple of different rods.
http://chevy.oldcarmanualproject.com/shop/1949_53/...
Member #189 Moderator and "22nd Year" Platinum Supporting Member
10-28-20 09:18 PM - Post#2806458
http://chevy.oldcarmanualproject.com/parts/1929_54...
Linkage for Powerglide.
29-41, 42-48, 49-54 Moderator
2019 Ford Ranger Lariat Super Crewcab |
chevyivar
Loc: Norway
Reg: 08-30-12
10-29-20 10:24 AM - Post#2806501
Page 82, Rod (A)
Cheers:)
chevyivar
Loc: Norway
Reg: 08-30-12
10-29-20 10:26 AM - Post#2806502
Ill keep that drawing Keith, Thanks:), it's the rod 4019.
dsacton
Loc: Boulder, CO
Reg: 11-01-11
10-30-20 10:43 AM - Post#2806604
Got it! OK, I will see if I can take some detailed measurements this weekend, and post it here.
buddhabelly
Loc: Calgary, AB
Reg: 12-05-14
10-30-20 12:53 PM - Post#2806617
Hi, just trolling the forum and came on this request. I looked at the exploded view of the shifting linkage with a magnifying glass and there seems to be 2 rods with the number 4.019. I assume one is the actual shifter while the other appears to go to the carburetor linkage. Do you only need that carburetor rod that attaches to the 4.041 lever or all the connected levers and pivots between the rod and carburetor?
dsacton
Loc: Boulder, CO
Reg: 11-01-11
10-30-20 03:40 PM - Post#2806638
In response to buddhabelly
Good point. OK, which rod do I need to measure? The one shown in blue or in red?
buddhabelly
Loc: Calgary, AB
Reg: 12-05-14
10-30-20 03:56 PM - Post#2806639
I've got the red rod pulled from a '53, if it is the correct one, to pull measurements from.PM if you want to simply purchase it, as I do not have a carb and associated linkage to return to stock.
10-30-20 06:02 PM - Post#2806648
He said he needed the kickdown rod which is the red one.
chevyivar
Loc: Norway
Reg: 08-30-12
10-31-20 03:06 PM - Post#2806710
Great drawing, thanks:)
chevyivar
Loc: Norway
Reg: 08-30-12
10-31-20 03:07 PM - Post#2806711
As Keith mentioned, it's the red one. pm sent
chevyivar
Loc: Norway
Reg: 08-30-12
10-31-20 03:40 PM - Post#2806712
Meassurements are probably not needed if Buddhabelly got the right rod, ill let you know.Thanks guys for your time and effort:)
Edited by chevyivar on 10-31-20 03:45 PM. Reason for edit: No reason given.
dsacton
Loc: Boulder, CO
Reg: 11-01-11
11-03-20 10:10 AM - Post#2806930
No problem! Let me know if you still need it.
