Username Post: Camshaft ID        (Topic#363021)
dennis h. pateras
Reg: 07-04-13
10-22-20 08:22 PM - Post#2806005
I have a 1984 350 4 bolt main engine. I read that these had the -962 camshaft that was used in the 350/350 hp engines. Anyone know if this is true? Thanks for any info.
Member #409
10-23-20 07:09 PM - Post#2806065
    In response to dennis h. pateras
There was no 350 hp engine option in 1984. So no.
dennis h. pateras
Reg: 07-04-13
10-23-20 07:38 PM - Post#2806067
    In response to Rick_L
That’s what I thought.. ok thanks
grumpyvette 73
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
10-24-20 01:00 PM - Post#2806108
Execution time: 0.112 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:23 PM
