Username Post: Engine noise?!        (Topic#362956)
Crisserranomurillo
Reg: 10-18-20
10-18-20 12:45 PM - Post#2805703
So rectory I’ve put back together a 327 for my 64 impala, I made it run fine after wards I noticed transmission wasn’t working so I had to take everything back out, mean while I installed a new oil pump and removed the intake manifold to check the lifters and put everything back, once it was I. The car again, it started to make this galloping maybe even sucking sound from on top of the carburetor but it only happens when you rev the engine quickly, it also backfires from the passenger side exhaust and it also pops from time to time in the front as well can anyone help me Identify where the problem is I would appreciate it greatly hears the URL [youtube][/youtube] https://m.youtube.com/watch?v=8t5ORhjIsQE
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
10-18-20 01:21 PM - Post#2805708
    In response to Crisserranomurillo
Check the basics, firing order and timing since you took out the distributor. Make sure your not one tooth off.
How did you check the lifters? Just look or did you loosen them?
Edited by turbo38s10 on 10-18-20 01:22 PM. Reason for edit: No reason given.
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
10-18-20 01:26 PM - Post#2805709
Backfiring usually indicates a lean condition. Check for leaks around intake manifold and carburetor base.
10-18-20 03:12 PM - Post#2805714
    In response to 55Brodie
Is it missing? Sounds to me like it might be missing.
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
10-19-20 04:57 AM - Post#2805750
When you say "it pops from the front", are you saying it is backfiring through the carburetor? If the timing is right and the plugs wires are where they should be I would suspect a worn cam lobe. Had that happen to me with a 327 years ago.
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, EZ Wire, Vintage Air, Ididit column, Cruise/Tilt, PS, 59 Corvette Steering Wheel, 4-Wheel Discs, Posies Rear Springs, Coker Radials, Nova 10-bolt, Mustang II, NCA Continental Kit.
64ss409
Reg: 12-04-02
10-19-20 06:51 AM - Post#2805754
I wonder if the "pops from the front" may be a cracked or leaking exhaust manifold.
Ron
1962 SS convertible, 327/250 4 spd
1956 IH pickup, 327
Crisserranomurillo
Reg: 10-18-20
10-19-20 10:49 AM - Post#2805771
    In response to turbo38s10
I went to each piston got it to TDC well looked like I got it from TDC and then loosened them and rotated the pushrod back and forth till I felt the rocker arm grabbed and then I did a quarter turn to tighten it, I went through all with that same process and followed the firing order when I did it.
Crisserranomurillo
Reg: 10-18-20
10-19-20 10:50 AM - Post#2805772
    In response to 64ss409
i'll check for any cracks or leaks
Crisserranomurillo
Reg: 10-18-20
10-19-20 10:52 AM - Post#2805773
how can you check if the cam lobes are worn other than pulling the engine out again?
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
10-21-20 07:26 AM - Post#2805897
You should be able to pull the cam without removing the engine from the car. There also might be an easier way to find a worn cam lobe but I don't know what that might be.
Vern
junky
Loc: Northeast CT
Reg: 06-27-10
10-21-20 01:01 PM - Post#2805910
Take the valve covers off, and crank the engine over. The valve rocker arm that doesn't move much is the one that has the bad cam lobe.
Crisserranomurillo
Reg: 10-18-20
10-21-20 03:37 PM - Post#2805922
    In response to junky
thanks ill try it out!
Execution time: 0.173 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:44 AM
