Username Post: Ball and spindle sized in steering knuckle        (Topic#362955)
mauryfrench
“2nd Year” Gold Supporting Member
mauryfrench
Loc: Wylie, TX
Reg: 12-26-19
10-18-20 11:03 AM - Post#2805692
Good day everyone.
I had a lower ball joint come apart on the passenger side, dropping the control arm down. I got it towed to my driveway. After removing the control arm, I find the castle nut and ball seem to be seized in the steering knuckle.
And as you can probably figure, I cannot get a lot of leverage on the nut because a) the knuckle/wheel hub are moving all around with the lower control arm disconnected, and b) there is not a lot of room to work on top of that.
Any ideas? Those of you who remember any of my posts may remember I am not a mechanic and learn a lot of this stuff as I go.
I have been blasting the nut with penetrating oil but who knows if that is helping or not.
Once I get past this issue, I will likely be asking how to get that damn coil spring back in. But, one thing at a time.
Maury French
Wylie, TX
1998 Chevy ECLB 5.7 Vortec
Edited by mauryfrench on 10-18-20 11:05 AM. Reason for edit: No reason given.
Senior Moderator
10-18-20 11:09 AM - Post#2805695
    In response to mauryfrench
You can probably get a tie rod puller tool or similar tool in there to pop the broken ball joint loose. This is a fairly common failure on high-mileage trucks but I've never had to battle it myself so the perfect tool for the job isn't in my memory.
Site Ambassador
10-18-20 11:43 AM - Post#2805700
    In response to someotherguy
I would just grind or cut the nut off and then use a ball joint tool to push out the remains.
1957 Cameo Carrier
mauryfrench
mauryfrench
Loc: Wylie, TX
Reg: 12-26-19
10-18-20 12:58 PM - Post#2805704
    In response to wagonman100
I wondered about cutting the ball off with a sawzall and metal blade, but now that I really look at the taper of the spindle, I see that won't work. I may have to look at grinders.
Maury French
Wylie, TX
mauryfrench
mauryfrench
Loc: Wylie, TX
Reg: 12-26-19
10-18-20 01:00 PM - Post#2805706
It won't go thru until the castle nut is off, and that is my problem. I did look up the tie rod puller though; that looks greats for forcing the spindle out after I get the nut off.
Maury French
Wylie, TX
mauryfrench
mauryfrench
Loc: Wylie, TX
Reg: 12-26-19
10-18-20 02:57 PM - Post#2805713
Follow-up everyone; I looked at it one more time and from one more angle, and managed to get the nut to pop right loose. So easy I don't know why I had such difficulty yesterday.
Thanks all for the help.
Maury French
Wylie, TX
Senior Moderator
10-20-20 08:03 AM - Post#2805816
Good job! Sometimes that's all it takes, just digging in and refusing to fail.
thx1138v2
Reg: 05-01-14
10-22-20 04:20 AM - Post#2805948
It probably took the penetrating oil overnight to work. I just recently did my front end and that's the first thing I did was spray all the threads with penetrating oil - PB Blaster - and let it sit overnight.
I had a similar problem with A/C fittings and solved it the same way.
It's to the point where that's the first thing I do any more.
Execution time: 0.164 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:12 AM
