Username Post: 15 inch 6 lugs ,5.5 lug patern trailer wheel        (Topic#362942)
Sal
Reg: 05-18-07
10-16-20 06:07 PM - Post#2805624
will these trailer wheels fit a 1962 chevy c10?
Senior Moderator
10-17-20 06:18 AM - Post#2805632
    In response to Sal
The bolt pattern is correct but without more info like the offset and hub bore, can't answer for sure. It's a "probably" though!
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
10-17-20 08:13 AM - Post#2805639
    In response to someotherguy
You also need to be careful of the hub size. Typically, the wheel has a centering circle that fits tightly around the hub. Those can be different sizes. I'm not sure how important that hub is during operation, only that it can be different. I borrowed a trailer once and had a wheel fail partially because somebody had used a Toyota wheel on it, but the centering hole was the wrong size. They cut out the middle with a blow torch and weakend the wheel at the center. Overloading the trailer was probably a bigger problem, but the result was a wheel falling off the trailer at 40mph, which wasn't fun.
Sal
Reg: 05-18-07
10-21-20 05:24 PM - Post#2805928
    In response to jktucker92
ok,thanks for the information, I found some original C10 chevy wheels with the hook/prung to attach the hubcaps to them but I had to pay a pretty penny for them, it was difficult to find those wheels!
Execution time: 0.174 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:09 PM
