Username Post: Door Hinge Bushings        (Topic#362940)
Junk86
Reg: 03-15-19
10-16-20 03:27 PM - Post#2805609
I have a sagging drivers side door that new door hinge bushings did not correct. The problem appears to be with the frame side hinges , which by the way is welded. Question: If I install new bushings in the welded hinges, do I leave the door side hinges without bushings, or should all 4 hinges have bushings installed?
1973 Chevy Nova
Edited by Junk86 on 10-16-20 03:28 PM. Reason for edit: No reason given.
docjns1
Gold Supporting Member
docjns1
Loc: upstate NY
Reg: 11-12-19
10-19-20 05:04 PM - Post#2805787
    In response to Junk86
Only the body side gets bushings. If the originals are badly worn and ovaled, GM makes (made?) larger OD bushings as replacements. Hinge would need to be drilled out to accommodate them, if memory is correct, GM P# 20429500...I believe also available thru aftermarket at most mass merch stores. Pins are hardened but can be worn as well, best to check them carefully too.
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
Execution time: 0.241 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:50 PM
