Username Post: Manifold bolts        (Topic#362933)
Falcon65
Falcon65
Reg: 10-15-20
10-15-20 07:47 PM - Post#2805558
Just purchased a 94 Chevy 3500HD with a 454 N series motor this thing was a real basket case I had to have it delivered by rollback the guy said everything was in the bed. I wound up short blocking the motor it was rusted so bad, got heads reworked no biggy. replaced 4 valves. been a bear getting pushrods finally went to Chevy dealer and looked at their books 2 different sizes?? Got that resolved now the intake I can't find a diagram anywhere as to where the studs go and normal bolts any one have an idea? and finding another BB in my location is impossable. Thanks for any help
Edited by Falcon65 on 10-15-20 07:48 PM. Reason for edit: No reason given.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
10-16-20 07:11 AM - Post#2805576
    In response to Falcon65
Fastener Type Torque Specs
Main Cap Bolt (396-427, 2-Bolt) 95 ft.-lbs.
Main Cap Bolt (396-454, 4-Bolt, Inner and Outer) 110 ft.-lbs.
3/8 in. Connecting Rod Bolt 50 ft.-lbs.
7/16 in. Connecting Rod Bolt 67-73 ft.-lbs.
Cylinder Head Bolts, Long 75 ft.-lbs.
Cylinder Head Bolts, Short 65-68 ft.-lbs.
Screw-In Rocker Arm Studs 50 ft.-lbs.
Intake Manifold Bolts (Cast Iron Head) 25 ft.-lbs.
Oil Pump Bolt 65 ft.-lbs.
Cam Sprocket Bolts 20 ft.-lbs.
Harmonic Damper Bolt 85 ft.-lbs.
Flywheel/Flexplate Bolts 60 ft.-lbs.
Pressure Plate Bolts 35 ft.-lbs.
Bellhousing Bolts 25 ft.-lbs.
Exhaust Manifold Bolts 20 ft.-lbs.
Edited by grumpyvette on 10-16-20 11:54 AM. Reason for edit: No reason given.
steve65
steve65
Loc: New Westminster BC
Reg: 09-25-13
10-16-20 10:28 AM - Post#2805594
Are you talking about intake or exhaust manifolds? I've got a 454 in pieces in my kitchen and don't recall any studs on the intake manifold. There are a couple(?) on the exhaust side.
Pic of one head attached, the other is already stripped down. There is one just below the temp sender on this one. But....not entirely sure that's the hole it came out of.
Steve
Attachment: stud.jpeg (74.93 KB) 1 View(s)
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
scrambldcj8
scrambldcj8
Loc: Belchertown, MA
Reg: 04-06-03
10-16-20 10:38 AM - Post#2805596
  • Falcon65 Said:
….. been a bear getting pushrods finally went to Chevy dealer and looked at their books 2 different sizes??
Yes, push rods are different lengths on a BBC. IIRC length is 8.280" intake and 9.250" exhaust.
Falcon65
Falcon65
Reg: 10-15-20
10-17-20 06:06 PM - Post#2805660
    In response to steve65
we must have different motors all most half of my intake manifold bolts are studs for brackets throttle linkage brackets even my thermostat has studs to mount a bracket for the wiring. I've almost figured it out I'm ashamed too say I saw one locally and followed him home, he was weirded out a little but when I explained he popped the hood. Thanks for the help anyway just wasted $50 bought a complete set of GM manuals on a 95 waste of time and money going to have to post another on different subject
Site Ambassador
10-17-20 06:40 PM - Post#2805663
When it was said there are no studs for the intake manifold, he meant that all of the fasteners that hold the intake to the heads are bolts, no studs. You wouldn’t be able to install the intake if there were studs there. There certainly were studs used elsewhere in the intake.
1957 Cameo Carrier
Senior Moderator
10-18-20 11:07 AM - Post#2805694
    In response to wagonman100
Maybe just a confusion of terms. Not regular studs, but double-ended bolts, like are used on most of the TBI & Vortec engines on the intake manifold. There are varying sizes and positions due to what he said - throttle and accessory brackets, stabilizer rods, etc.
IgnitionMan
Reg: 04-15-05
10-18-20 11:19 AM - Post#2805696
I have actually done intake manifold to head studs, not that hard.
Install manifold with stock bolts, and get it torqued. Come back after 24 hours, and ONE BOLT AT A TIME, remove a bolt.
Install a fully threaded Allen set screw, long enough to fit correctly down the head threads, add flat washer, and nut. torque, done.
Every time I did this, I did it for looks, NOT for practicality. It is time consuming, and makes servicing a pain, but, it sure does make 'em take a closer, second look.
Falcon65
Falcon65
Reg: 10-15-20
10-18-20 11:46 AM - Post#2805701
    In response to someotherguy
thanks I guess my old terms are out of date. I was referring to the bolt with an attached nut midways that allows you to mount a bracket on top and lock down with another nut
TAT_2
Member #26 "19th Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
10-18-20 03:41 PM - Post#2805716
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANIV- RUBY RED- LT1/6SPD/RAG TOP
NEXT ?
IgnitionMan
Reg: 04-15-05
10-18-20 04:40 PM - Post#2805719
Falcon, those double studs work good as well.
Execution time: 0.266 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:17 PM
