Username Post: TAILLIGHT PROBLEM        (Topic#362928)
Shoebox
Shoebox
Reg: 09-28-03
10-15-20 02:28 PM - Post#2805535
First some background, my work in progress 55 has an AAW Classic Upgrade kit which at this point is installed from the dash back, nothing firewall forward yet. I'm using the AAW headlight and ignition switches. The battery is mounted in the trunk and am using Technostalgia LED taillight assemblies which have a "triple flash" brake light function, meaning whenever brakes are applied, they flash 3 times fast and then remain on. Just did a cautious initial battery connection......... no smoke! However with ignition switch and headlight switch off, the taillights and both turn signal indicator dash lights are on. When the headlight switch is pulled out to first position the license plate lights come on as they should but the brake lights do the triple flash. The mechanical brake light switch apparently isn't doing anything. The dash lights up and dims as it should. Although in the end it won't be used, there is a 3rd brake light lead and it also is live. Where could the power be "getting into" these circuits? I'll continue to study wiring diagrams, but any input is most welcome. Thank you!
Shoebox
>> My Cool 55 <<
55 2dr Sedan- 454 4spd, R&P steering, 4 whl disks
32 Roadster- Nailhead 401, Tremec 5 sp
Shoebox
Shoebox
Reg: 09-28-03
10-16-20 06:34 AM - Post#2805573
    In response to Shoebox
An additional fact regarding this electrical issue is that whether the brake light switch is fully extended or depressed, the 3rd brake light lead is live.
Shoebox
>> My Cool 55 <<
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
10-23-20 03:59 PM - Post#2806049
Disconnect the tail lights from the rear body harness and see if you have voltage on the brown wire WITHOUT it being attached to the tail lamps. I suspect no, because the tail light and tag light are the same circuit and the tag light does not come on until you pull the headlight switch knob out by your own admission. I hate to condemn the tail lights, but LEDS will light up with milli-volts of power directed to them. My guess is that something is either wrong in the logic, or the connections are not correct.
Donny
Edited by aawtech on 10-23-20 04:01 PM. Reason for edit: No reason given.
Execution time: 0.153 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:36 AM
