Username Post: Can i replace power brakes from 85c10 with manual brakes from a 73 c10        (Topic#362898)
lancebon
Reg: 10-13-20
10-13-20 10:31 AM - Post#2805377
I have 3 c10s 73,74,85 I want to replace power brakes on 85 with 73 manual will it work?
1965C-10
1965C-10
Loc: San Tan Valley AZ "Phoeni...
Reg: 11-18-01
10-13-20 08:43 PM - Post#2805412
    In response to lancebon
Why would you want to?
I converted my 1965 C10 to have power disc brakes and it stops easier and faster.
10-14-20 05:31 AM - Post#2805421
    In response to 1965C-10
Welcome to the site lancebon. Hyrdoboost and vacuum power brakes have advantages and disadvantages. Several parts do have to be swapped. Do you have manuals for both? I worked on an '07 Silverado 1500HD last week. The brake lights were not working. To my suprise, it had factory hydroboost brakes. Diesels used them due to poor vacuum.
Do you have all the parts needed? Are there any differences in engines? I've never done a conversion so I can't help with details.
'08 GMC Acadia 3.6L SLE
VanLife
Reg: 03-20-18
10-20-20 01:55 PM - Post#2805844
be mindful regarding unusual conversions .
Mechanics often refuse to work on them.
Like I can't get a mechanic to work on mine if they are AAA grade mechanics. And many others will refuse to work on it once they realize something so extensive has been modified.
It has to do with liability and risk losing their mechanics license. and or certifications.
For example Mechanic I know refused to work on park brake system because the owner wanted him to modify it. He explained he could lose his shop if he was caught modifying it for the owner. .
when asking Questions its related to van I own: 1987 GMC 3/4 ton G2500 vandura, V6, No AC, standard length. 3speed trans(no overdrive).
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
10-24-20 09:39 PM - Post#2806131
    In response to VanLife
Of course it would work. Assuming that you transfer the whole system...but what if you don't get it all?
BTW, manual brakes have a shorter stopping distance (twas a question on "Hollywood Squares").
But, it would be a step backwards. And, for the other reasons mentioned, it is highly illogical...IOW, it don't make no sense.
Edited by Stinky on 10-24-20 09:40 PM. Reason for edit: No reason given.
Execution time: 0.291 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:13 AM
