xltpilot
Reg: 10-13-20
10-13-20 06:28 AM - Post#2805367
Hi All, new to the forum.
I am looking at a 50000 miles preserved car, has no rust that can be seen since it is heavily oil undercoated. Was this the way back in the 50's to preserve them, or should I be concerned that this is a way to conceal rust?
Also, the owner (Original purchaser from Oct 56) changed out the single 4 barrel carter to a dual set up with the GM intake, and has the batwing air cleaner, is this an issue?
He also changed the steering wheel to a 59 model wheel.
And did a 3 speed floor shifter, and cut the tunnel.
Currently asking concours money $50000, but Hagerty see's it differently that a #2 car is more likely in the 30's. Question is, with these mods, is it still a #2 Car, and I only say this because "HIS" Appraiser put it in #2 condition, and 95% original. Thanks!
Site Ambassador
10-13-20 07:25 PM - Post#2805409
In response to xltpilot
Welcome to CT. It depends on who you talk to. Purists will say he devalued the car. Hot Rodgers will say he improved it. The intake and carbs. and the steering wheel can be easily changed back if desired (though I personally like those changes). The shifter moved to the floor makes for easier driving and is okay as long as it wasn’t a hanky job. That bat wing air cleaner is worth some bucks. The oil undercoating is not typical, but not unheard of. Just inspect things carefully for corrosion.
1957 Cameo Carrier |
1971BB427
Loc: Portland,Or
Reg: 12-06-09
10-14-20 07:13 AM - Post#2805432
In response to wagonman100
Considering the change to floor shifter being a major change because of the floor modification, I'd say it's not nearly a #2 car, or a $50k car. The intake isn't a big deal as it's easily returned to original if a concours car is what you want. Same for the steering wheel, as it's easily reversible. But the shifter change is huge, and really hurts a concours judging.
I'd say he took a $50k car and made it a $30k-$35k car.
The undercoating is an issue if it's not original. I'd have it closely examined if you are serious. But not sure I'd ever get serious at the asking price.
1969 Suburban 2wd 350
1939 Chevy pass. coupe 350/700R4
1937 Austin gasser 327/TH350
Edited by 1971BB427 on 10-14-20 07:14 AM. Reason for edit: No reason given.
