Username Post: Iridium vs platinum? 2007 - 6.0L        (Topic#362896)
10-13-20 06:02 AM - Post#2805363
Did GM change the plug type after production? I've been asked to tune a 2007 1500HD. It was a surprise to see it labeled 1500 with 3/4 ton 8 lug wheels on it.
Did GM change the plug and gap size? I'm reading it should be 0.040 instead of 0.060. The owner mention he installed new A/C Delco plugs and they didn't work. He pulled them and installed a new set.
I plan on getting new wires after checking if it has round or square coils. It has evap codes too. So the single port valve behind the tank will be changed. So will the engine evap valve.
'08 GMC Acadia 3.6L SLE
10-13-20 07:50 AM - Post#2805369
Pretty sure both plat and Iridium plugs are pre gapped, not sure if they changed recommendations, but Iridium seems to be the better plug.
elcamino
elcamino
Reg: 03-30-00
10-14-20 07:28 PM - Post#2805477
1500HD would have to be the old body style referred to a "Classic". I looked in the AC Delco catalog and no Iridium plugs for that model are listed. Platinum is original equipment (OE)
Spark Plug
Part Number: 41-962
Product Notes:
Double Platinum Spark Plug
All; OE; GAP .040; All; Gap .040"
Per Vehicle: 8; Years: 2007-2007
Spark Plug
Part Number: 6
Product Notes:
Rapidfire Spark Plug
All; Gap 0.040in
Spark Plug
Part Number: R44LTSM
Product Notes:
Conventional Spark Plug
All; Gap .040; VIN: U, FI*
2017 GMC Sierra Denali Ultimate 6.2L / 8-sp Z95
2018 Polaris RZR S 900 EPS
10-15-20 04:25 AM - Post#2805492
    In response to elcamino
Thanks Mike!
The two choices are double platinum or rapid fire. It's a heavy use truck with a heavy equipment trailer. I better use double platinum. I fixed the A/C earlier this year on it. It had a bad low pressure switch. I replaced the orifice tube and cleaned the condenser. I was mad when I took off the high pressure hose. It leaked. After replacing it and charging it again, it blew ice cold. After a hot summer, it's still blowing cold. A new clutch fan keeps the motor and A/C cool.
Execution time: 0.146 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:33 AM
