Username Post: 94 chevy pickup stumbles and hesitates        (Topic#362847)
Legacychevypickup
Reg: 10-08-20
10-08-20 08:54 PM - Post#2805133
My 94 350 1/2 ton 4wd stumbles and hesitates on takeoffs with the egr connected. I get no check engine lights with the lead connected. With the lead disconnected the pickup runs fine,but I eventually get a check engine light. I have replaced the plugs,plug wires,the rotor,and rotor cap. The throttle body was replaced this year because of worn bushings.
Any ideas what could cause this issue.
Sabino
Reg: 07-16-05
10-11-20 09:17 AM - Post#2805251
    In response to Legacychevypickup
I assume code is a 32-egr not working when you get one when it’s disconnected?
Did problem start when the TBI was replaced or before/after?
If at same time, perhaps check vacuum line is to correct place, I don’t recall where it should be but seems like valve is opening but perhaps too fast.
Regardless, seems like troubleshoot egr is place to start.
There’s a good egr troubleshooting here https://www.chevytalk.org/fusionbb/showtopic.php?t...
65 Belair 350
68 Camaro 327
93 Suburban 5.7L TBI
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
10-11-20 07:42 PM - Post#2805283
Are you sure you have the EGR vacuum control vale connected properly?
One port is open to atmosphere and the other is the vacuum source line.
Attachment: C0151DE3-B37C-4481-90F4-601A831A76BB.png (1.13 MB) 13 View(s)
Greg
‘01 Silverado 2500HD 8.1/Allison 1000 Xcab/LB
'00 Explorer XLT 4.0 SOHC V6 Auto
'95 K1500 Z71 EC Short Step 5.7L+0.040/NV3500 SOLD
Senior Moderator
10-12-20 06:19 AM - Post#2805301
    In response to CowboyTrukr
If it is hooked up correctly (the smooth nipple is the one that should be open; from factory they usually had a small foam filter attached) - then the EGR valve is likely bad (broken internal spring opening too easily) or the wrong part #.
Todd G
Reg: 10-13-20
10-13-20 05:34 PM - Post#2805398
Reading these articles got me thinking about mine doing about the same thing except my egr solenoid Has power to it but dose not seem to have a ground could yours be like that , l have not solved mine but pretty sure I m going to ground the wire and then make sure the egr valve is working properly.
Execution time: 0.483 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:04 PM
