apix17
Loc: San Francisco Area
Reg: 12-22-07
10-02-20 06:25 PM - Post#2804696
I think the clip on my clutch fork that goes on the bell housing pivot ball is damaged or worn as the fork can be moved around quite a bit and at an angle it should not go to. My question is can I replace the clutch fork without removing the transmission. This is on a small block. Appreciate any input. Thanks
55MAS
Loc: North Coast, USA
Reg: 12-19-01
10-03-20 06:42 AM - Post#2804715
In response to apix17
Depending on the fork and bellhousing involved it may be possible. But don't waist you time. Pull the Transmission. Clean and inspect the fork, fork pivot, release bearing, Pilot bearing in crank, input shaft, transmission nose on which the bearing slides. Replace the worn parts and lubricate during reassembly. Then you know it will be good to go for many, many miles.
apix17
Reg: 12-22-07
10-03-20 10:14 AM - Post#2804731
In response to 55MAS
Thanks 55. What you suggested sounds reasonable. I will pull the tranny and see what the problem is. Thanks.
f.i.57chevynut
Loc: Granada Hills, CA
Reg: 03-04-09
10-04-20 08:18 PM - Post#2804842
The fork spring can be replaced, at least it used to be serviced by GM. I bought them in years past. Yes, you'll have to pull it apart anyway.
55MAS
Reg: 12-19-01
10-06-20 02:21 PM - Post#2804980
In response to f.i.57chevynut
I've seen them on eBay.
