Username Post: cav backup lights        (Topic#362772)
995jim
995jim
Loc: Ohio
Reg: 12-17-06
10-01-20 06:13 PM - Post#2804626
Hi, my 05 cavalier, with stick shift has the backup lights staying on constantly. Not sure where to look for a faulty switch or sensor.
any info would be be very helpful.
thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
10-01-20 08:03 PM - Post#2804633
    In response to 995jim
Should be the same as your cavalier.
Hope this helps
https://www.youtube.com/watch?v=prcUTN_Iyoo&a mp;ab...
Old School GM fan FOREVER
995jim
995jim
Loc: Ohio
Reg: 12-17-06
10-02-20 04:38 PM - Post#2804683
    In response to rockfangd
well i pulled the switch and tested continuity and the switch has continuity when the pin is pushed in so i plugged it in and pushed the pin in and still no lights out. I also jumpered between the plug connections So im not sure where to look next ,
thanks jim
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
10-02-20 06:52 PM - Post#2804693
Ok few questions here.
Key off. Lights on or off?
If switch is unplugged do lights go out?
See if there is a reverse lamp relay... May be stuck.
Have you tried disconnecting the battery for a minute or so?
995jim
995jim
Loc: Ohio
Reg: 12-17-06
10-03-20 10:24 AM - Post#2804729
here are my test results
key off- lights off
switch unplugged-lights on
batt disconnect reconnect after a few min-lights on
jumper plug at switch-lights on
no power at plug to switch
door closed,car running or not,nuetral,headlights on or off,-lights stay on
I dont see a specific relay for B U lamp but i did pull the relay in the dash panel DRL relay and lights stay on
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
10-03-20 06:07 PM - Post#2804763
Ok.
I will try to find a diagram.
For whatever reason wiring diagrams appear to be worth gold over the last years. All of my sources for wiring diagrams are gone.
If I could see a diagram I could lead you in a better direction.
I would figure the trigger is a negative(-)
Which may be grounded right now and causing the lights to stay on. It would be grounded in the harness to the switch which is only controlled when the key is on
Execution time: 0.164 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:26 AM
