Username Post: 1948 Businessmans Coupe        (Topic#362761)
gregphoto403
Reg: 09-30-20
09-30-20 05:12 PM - Post#2804570
I need to remove the seat in my '48. I read that you pull up on the front of the seat to remove the bench portion and access the mounting bolts. I have tried to, unsuccessfully, without pulling too hard.
Before I really start to pull on it I thought I'd reach out and see if anyone has done it before.
09-30-20 06:14 PM - Post#2804571
    In response to gregphoto403
Welcome to ChevyTalk. I have had mine out a few times. But don't remember the procedure. Will take a look tomorrow and see what I did.
29-41, 42-48, 49-54 Moderator
1946 Chevy 1/2 ton pickup, stock. Purchased 11/18/17. Sold 9/16/20
gregphoto403
Reg: 09-30-20
09-30-20 07:27 PM - Post#2804572
Thanks!
ruscar
Loc: GA
Reg: 12-22-06
10-01-20 06:48 AM - Post#2804594
Yes, what you read is all you do. No fasteners or clips involved.
Try one front corner then the other. Should break free.
Good luck.
Russell
gregphoto403
Reg: 09-30-20
10-01-20 08:43 AM - Post#2804596
    In response to ruscar
Thanks Russell!
Greg
10-05-20 05:59 PM - Post#2804908
Did you get the seat out?
gregphoto403
Reg: 09-30-20
10-22-20 06:00 PM - Post#2806001
I did thanks. It was as simple as pulling the bottom up and then removing the floor bolts!
10-22-20 06:28 PM - Post#2806003
Suggestion if you haven't reinstalled the seat frame. I used studs instead of the original bolts. It makes lining up the seat frame a breeze.
Execution time: 0.236 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:27 PM
