Username Post: Sandwich plate        (Topic#362729)
Darren Curtain
Reg: 03-29-20
09-28-20 03:12 AM - Post#2804406
Hi new to sbc engines just wondering if I need to use a sandwich plate between block and th350 transmission??Thanks
09-28-20 06:49 AM - Post#2804416
    In response to Darren Curtain
What year model engine? Does it have provisions for a block mounted starter? 57, 283's had block mounted starters, earlier engines didn't. Link to Starter monting.
56sedandelivery
Gold Supporting Member
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
09-28-20 10:31 AM - Post#2804439
    In response to acardon
^^^Only the Turbo-Glide transmission equipped engines had block mounted starters, although all 57 V-8's had the blocks tapped for them, including the 57 265, that Turbo-Glides never came bolted up too. It was 63, with the 327, that all those 327 engines came with a block mounted starter, the 283's still used the bell-housing mounted starters. 64 on, all engines used block mounted starters, although some trucks used bell-housing mounted starters until the late 70's. I can't say I ever saw a factory Chevrolet V-8 with a spacer plate between the engine and transmission. Fords are an entirely different deal. I am Butch/56sedandelivery.
Darren Curtain
Reg: 03-29-20
09-28-20 12:10 PM - Post#2804447
Thanks guys the engine is out of a hq holden(aussie car)around 1972 and has block mounted starter and as coming from fords yep they do stuff different ???????? thanks for the help????
Edited by Darren Curtain on 09-28-20 12:10 PM. Reason for edit: No reason given.
Algoma56
Reg: 03-14-05
09-30-20 10:42 AM - Post#2804556
Normal SBC do not use a "sandwich plate" like the SBF's do. The Ford plate is used to accurately locate the starter in relation to ring gear.
I have both types of engines.
Execution time: 0.117 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:07 AM
