Username Post: Dual resivoir        (Topic#362669)
rls8836
Loc: North La.
Reg: 01-30-02
09-21-20 02:19 PM - Post#2803982
What brake resivoir do I buy at a auto parts store to go from single to tandem resivoir. 55 Chevy, all drum brakes
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
09-23-20 08:50 PM - Post#2804188
    In response to rls8836
a picture is posted on post #2744453
sorry don't know how to make the link,
but as usual there is more to the story
VC56S 2 door Sedan, 40 Years
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
09-23-20 09:15 PM - Post#2804192
M-C100L, 158464, F1A20-10-01, numbers from CPP box,
don't have a wagner or any other numbers
rls8836
Loc: North La.
Reg: 01-30-02
09-24-20 05:19 AM - Post#2804199
    In response to Bad56Sedan
Thank you
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
09-24-20 07:12 AM - Post#2804204
The all drum configuration requires residual pressure (about 10 psi) be retained in the system. SOME master cylinders sold by vendors (advertised as drum/drum components) do not have the check valves integral to the cylinder.
Those w/o the integral check valves may still be used. Separate/external 10 psi residual pressure valves are required; one for the 'front system', one for the 'rear system'.
Proportioning valves are not required (and serve no purpose) on the all drum systems. The approx 60%-40% front/rear brake force distribution is accomplish by using wider drums/shoes in the front. Hydraulic pressure is uniform throughout the system.
Just info you may already know.
Pete
YOUNG57
Loc: Tennessee
Reg: 12-06-10
09-26-20 10:09 AM - Post#2804326
    In response to japete92
“Proportioning valves are not required (and serve no purpose) on the all drum systems. The approx 60%-40% front/rear brake force distribution is accomplish by using wider drums/shoes in the front. Hydraulic pressure is uniform throughout the system.”
Also, the wheel cylinders are different sizes, the fronts are 1-1/8” and the rears 1”.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
09-26-20 02:28 PM - Post#2804335
Did you find the firewall studs are too short?
Nothing is easy.
Bruces 57
Reg: 01-03-07
09-27-20 06:50 AM - Post#2804363
Hello;
What do you want adding parts to your car that weren't intended to be there!
Aint it fun? But then again we need to bring our cars up to much better safety standards!!!
Bruce
Execution time: 0.219 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:04 PM
