Username Post: High beams        (Topic#362622)
tooomuch7
tooomuch7
Loc: Hartford Ohio
Reg: 03-18-02
09-18-20 04:24 AM - Post#2803720
My son has a 2015 truck,the high beams won’t shut off. When he pulls the fuse they shut off,What should we be looking at to find the problem.Any suggestions?
http://www.picturetrail.com/gallery/view?p=999&gid=5387542&uid=2695815&members=1
09-19-20 09:21 AM - Post#2803806
    In response to tooomuch7
i would guess the switch, but it could also be a body controller. nowadays the swithces are all plastic. pull the cover off to see if there are any craked plastic peices in there.
tooomuch7
tooomuch7
Loc: Hartford Ohio
Reg: 03-18-02
10-17-20 07:02 PM - Post#2805665
    In response to bobb
Replaced the switch,high beams still won’t shut off.
10-18-20 04:38 AM - Post#2805675
Disconnect the battery for 10 min or more. Today's vehicles are like computers. They need a reboot now and then. It should also have a relay for high beams. Swap the relay with another similar one.
'08 GMC Acadia 3.6L SLE
tooomuch7
tooomuch7
Loc: Hartford Ohio
Reg: 03-18-02
10-18-20 10:35 AM - Post#2805690
Ok,I will tell my son to try it,thanks.
tooomuch7
tooomuch7
Loc: Hartford Ohio
Reg: 03-18-02
10-21-20 08:36 AM - Post#2805898
He told me he tried disconnecting the battery,it didn’t work. He also told me there is no relay on his truck because it doesn’t have LEDs.I don’t know if that’s right or not,will have to check into that.
VanLife
Reg: 03-20-18
10-21-20 07:44 PM - Post#2805933
Here is a possibility but NOT positive.
THe hot wire for normal beam and the wire for high beam Are connected somewhere. where the wire protective shell is too thin or cracked or melted or scraped away.
Allowing the current from normal beam to pass over to high beam
when asking Questions its related to van I own: 1987 GMC 3/4 ton G2500 vandura, V6, No AC, standard length. 3speed trans(no overdrive).
VanLife
Reg: 03-20-18
10-21-20 07:46 PM - Post#2805934
todays vehicles are computers. with power plants added to them.
elcamino
elcamino
Reg: 03-30-00
10-28-20 07:58 AM - Post#2806382
It he adding some aftermarket lights or is this problem with the original equipment? Also what kind of 2015 truck is it, some have different lighting.
2017 GMC Sierra Denali Ultimate 6.2L / 8-sp Z95
2018 Polaris RZR S 900 EPS
Execution time: 0.143 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:26 AM
