Username Post: abs sensor        (Topic#362597)
kmdakota1
Reg: 04-05-18
09-16-20 02:18 PM - Post#2803602
problem with abs kicking on at almost stop and in and out of turns. No engine light. Had front end alignment and tire pressure good. tested wiring to abs sensor all good. checked resistance through wire and also directly at abs sensor and both got 1.6. Tested voltage with car in drive on jackstands (12 mph idle) drivers side .6 passenger side .4 Passenger side takes a good 3-4 seconds to get that reading but drivers side is almost instant. Do abs sensors get lazy and is this voltage difference enough to activate abs? i read both sensors have to read the same. Hub bearing only two years old. they are Moogs sensor built inside.
10-18-20 01:38 PM - Post#2805711
    In response to kmdakota1
Same advice, which is what I do in my shop, that I give everyone, get an abs scanner on it and look at wheel speed inputs slowing down to zero, you will see one drop out before the others, that is the bad one or circuit.
Execution time: 0.414 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:39 AM
