Username Post: Thread sealant        (Topic#362594)
Johnny468
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
09-16-20 09:50 AM - Post#2803580
When installing NPT to AN adapters into a fuel pump, is there some type of thread sealant I can use on the NPT threads beside white teflon paste?
Possibly something more permanent that hardens when it cures?
Seems like the paste always deteriorates and discolors over time when used on fuel fittings.
Thanks,
Johnny
1965 Impala SS
505/4-speed/3.90
Member #409
09-16-20 10:45 AM - Post#2803588
    In response to Johnny468
I use teflon tape. Tape or paste, don't apply on the last thread, to keep it out of the fluid flow.
IgnitionMan
Reg: 04-15-05
09-16-20 10:57 AM - Post#2803589
    In response to Rick_L
I agree with Rick, completely.
Johnny468
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
09-16-20 11:33 AM - Post#2803590
    In response to IgnitionMan
So that's the trick, eh? Very interesting.
I've always applied the sealant all the way up to the end of the fitting.
Thanks for the response, I'll give it a try.
Johnny
1965 Impala SS
505/4-speed/3.90
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
09-16-20 09:26 PM - Post#2803623
I would suggest trying Permatex Aviation Form a Gasket, it has been around for many years and is gasoline resistant. I have used it with success for a long time.
Dave
09-20-20 08:59 AM - Post#2803875
    In response to dgstarr
Permatex Aviation Form A Gasket is my preference. I use it on liquid lines and gaskets. Great for coolant and oil sealing.
'08 GMC Acadia 3.6L SLE
IgnitionMan
Reg: 04-15-05
09-20-20 10:10 AM - Post#2803881
I have worked in the auto and motorcycle industries for a lot of decades, and the best sealer I have found is one that can be used with, or without gaskets.
Marketed under many names, such as Suzuki Seal, Yama-Bond 4, and its manufacturer name, Three-Bond, it seals gaskets (the blue, gray lines of sealer on intake manifold gaskets is this stuff), 1104, 1194, is great stuff.
This is also the gray sealer between bare metal to metal engine cases on motorcycles. It seals water, coolant, oil vacuum, name it. NOTE: It does not work with excessive heat, such as exhaust system joints and junctions.
Execution time: 0.113 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:31 AM
