Username Post: abs sensor on HHR        (Topic#362591)
kmdakota1
Reg: 04-05-18
09-15-20 07:52 PM - Post#2803548
problem with abs kicking on at almost stop and in and out of turns. No engine light. Had front end alignment and tire pressure good. tested wiring to abs sensor all good. checked resistance through wire and also directly at abs sensor and both got 1.6. Tested voltage with car in drive on jackstands (12 mph idle) drivers side .6 passenger side .4 Passenger side takes a good 3-4 seconds to get that reading but drivers side is almost instant. Do abs sensors get lazy and is this voltage difference enough to activate abs? i read both sensors have to read the same. Hub bearing only two years old. they are Moogs sensor built inside.
09-16-20 06:07 AM - Post#2803560
    In response to kmdakota1
Best way to pin this down to get an abs scanner on this, then you can can look at direct wheel speed inputs to to the controller, you will probably see one wheel drop out while others continue to read.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
09-16-20 07:55 AM - Post#2803572
You should try posting this in the HHR forum. Maybe you can get some help there.
Execution time: 0.085 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:39 AM
