Username Post: 95 C1500, 5.7 TBI        (Topic#362589)
93 low
Reg: 12-06-11
09-15-20 04:56 PM - Post#2803537
95, C1500, 5.7L, TBI, extended cab
The truck sat for a few weeks. If you turn the ignition key to the on position you have to wait 10 to 15 seconds You can hear a click sound (under the dash behind the gauges on the driver side) then all the dashboard warning lights come on and you can start the truck and it would run fine.
If you try to start the truck before the dashboard warning lights come on, the motor will turn over but doesn't start. No spark at the plugs, sprayed a quick blast of starting fluid and no change. Dashboard volt gauge reads 9 volts. Voltage at the battery is 12.65.
I've checked the fuses, driver side under the hood and driver's side end of the dashboard with a continuity tester and all fuses are good.
Now I don't hear a click, no dashboard lights, motor turns over but no start. The seat belt buzzer works.
Any suggestions would be greatly appreciated. Thanks
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
09-15-20 06:33 PM - Post#2803540
    In response to 93 low
Sounds like a bad ignition.
Not where the key goes, but the electrical part.
Located on the side of the column behind the dash panel
Old School GM fan FOREVER
Edited by rockfangd on 09-15-20 06:34 PM. Reason for edit: No reason given.
Senior Moderator
09-16-20 10:05 AM - Post#2803585
    In response to rockfangd
Agreed but on 95-up it's inside the column. It's also kind of a problem area on that newer style column.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
09-16-20 05:56 PM - Post#2803616
    In response to someotherguy
You are absolutely correct. Not like the saginaw.
Believe you have to split the column cover.
Not too bad to do
Execution time: 0.097 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:04 AM
