Username Post: Will 15" X 8" X 4.25" BS work on front?        (Topic#362586)
AmericanPie
AmericanPie
Loc: Camarillo, CA
Reg: 07-28-01
09-15-20 01:16 PM - Post#2803523
I'd like to run 15" X 8" Cragar S/S all-around but this size is only available in 4.25" BS.
I've read this may be a problem with front fender clearance. Will this BS work and what tire sizes would I be limited to in front? I'd like to run something like a 245/60-15 all around, if possible.
Edit: I've discovered that I can custom-order a 15" X 8" S/S wheel directly through Cragar with a 4.50" BS ("0" offset). Would that be the way to go?
1965 Impala SS 327, Crocus Yellow
Edited by AmericanPie on 09-15-20 02:38 PM. Reason for edit: No reason given.
65_Impala
Reg: 12-29-02
09-16-20 11:41 AM - Post#2803591
    In response to AmericanPie
That rim and tire wouldn't work on my car. It works on other cars though. The 0mm offset would be a safer bet if you can't try a borrowed wheel or measure it to know.
AmericanPie
AmericanPie
Loc: Camarillo, CA
Reg: 07-28-01
09-16-20 02:44 PM - Post#2803599
    In response to 65_Impala
Thanks. I've decided to order a set of 15" X 8" wheels directly from Cragar, custom made with "0" offset. I'll see if I can scrounge up a couple of used 245/60-15 tires off CL or maybe from a local tire store, and check them for front clearance before committing to a new set. I'm not worried about clearance in the rear.
65_Impala
Reg: 12-29-02
09-17-20 06:55 AM - Post#2803640
There's little concern on the front with 0 offset wheels.
AmericanPie
AmericanPie
Loc: Camarillo, CA
Reg: 07-28-01
09-17-20 09:38 AM - Post#2803656
Good to know!
Execution time: 0.128 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:36 AM
