Username Post: 1965 409 hard to start        (Topic#362584)
54BelairSC
Loc: Central Florida
Reg: 07-12-15
09-15-20 12:23 PM - Post#2803517
I have a 1961 impala with a 1965 409 engine. I am having a problem starting the engine. If the car sits for one or more days it is very hard to start. I pump the peddle sometimes 5 or more times and sometimes it will start and sometimes I hold the peddle all the way to the floor. So far I have replaced the starter, added a check valve on the fuel line just before the mechanical fuel pump, new carbs. If I remove the air cleaner, look down into the top of the carb. and pump the throttle I do see the gas squirting. The fuel pump is not leaking but it is a small block pump which I understand is OK to use on a 409. Any ideas would be appreciated.
Frank
Oshawa65SS
Loc: Burnaby BC Canada
Reg: 09-22-14
09-15-20 05:45 PM - Post#2803538
    In response to 54BelairSC
Maybe a float bowl is leaking
Is there evidence of fuel on the intake?
Ryan
Build date Dec. 21 '64 Oshawa
MarkISS
MarkISS
Loc: Brevard, NC
Reg: 05-14-18
09-16-20 09:22 AM - Post#2803578
    In response to Oshawa65SS
once running... is all ok? Idle, acceleration, etc? How's your vacuum, sparkplugs, wires, etc? When it does start, do the spark plugs "Spark" (i.e., pull each plug, checking both engine block ground and the ignition coil in the process?). Are you still using points?... check dist cap... clean and no moisture?
Mark
Mark - Brevard, NC - 66 Impala SS RestoMod
>>My detailed build thread link <<
jayoldschool
Reg: 09-03-18
09-16-20 02:21 PM - Post#2803597
    In response to MarkISS
What's the base timing?
Jason
65 Impala convertible 327/250 Maderia Maroon/black California black plate car
A White Sport Coupe
A White Sport Coupe
Reg: 08-19-10
09-16-20 03:37 PM - Post#2803604
Hi Belair
Is your choke working properly? Should be closed when cold. Fully open when hot.
Bob
Execution time: 0.113 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:11 PM
