Username Post: Leaking a thick oil, where from?        (Topic#362582)
tkruger
Reg: 07-19-18
09-15-20 08:53 AM - Post#2803508
I have a 1941 Master Deluxe with the original drive train.
After running it (idle in place) the last time a thick oil seems to have leaked from somewhere around the transmission. I could see a small drop on the drain plug but that is tight and seems to be a low spot.
Is there a common spot for these to leak from? Could it just be that I have a gasket that dried out? I am looking for a starting spot to go from. My kids and I are learning this as we go.
Little history:
Car was last known to be on the road in 1969.
My sons and I have been bringing it back to life over the last two years. All fluids have been replaced. After replacing the water pump, all the belts, hoses, plugs etc. it idles perfectly. Needs other work before going on the road and has not been run other than in neutral and in place (other than a 1 mile trip two years ago to make sure the tranny shifted properly, it did). Holds temperature perfectly and last was run for 20 minutes straight.
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
09-15-20 02:57 PM - Post#2803528
    In response to tkruger
Sounds to me like it might be the rear engine
main seal that's leaking ? Just my opinion !
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
09-15-20 03:40 PM - Post#2803533
Transmission oil has a specific smell if that is not obvious then it is probably engine oil leaking from the rear seal. Pull the clutch housing cover, if it is wet with oil inside then the source would be the rear main seal. Over time it will ruin the clutch disc.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
1971BB427
Loc: Portland,Or
Reg: 12-06-09
09-16-20 07:41 AM - Post#2803570
    In response to 2blu52
If it's gear oil from the transmission, there are a couple places it can leak from. My first guess would be the front seal, as wear over the years, or sitting and drying out can cause them to leak when you start driving again after a long rest.
The other less likely place is the gasket that seals the shifter plate. But that's not very common, even after sitting.
1969 Suburban 2wd 350
1939 Chevy passenger coupe
1937 Austin gasser 327/TH350
tkruger
Reg: 07-19-18
09-17-20 07:17 AM - Post#2803643
    In response to 1971BB427
What is leaking is far thicker than oil. The oil level also has not changed in all the time it has been leaking. I did notice a smell that I could not place in my garage, not a strong one but it is well ventilated too. When we are working the doors are all open. What is the smell like? What does the oil in the transmission look like? How thick is it? This is thick like syrup, does not flow well.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
09-17-20 08:21 AM - Post#2803650
Best way to describe gear lube smell is it stinks. Unlike any other lubricant in any other part of a car. You could easily pull a plug on the transmission and put a fingertip in it and then sniff it to compare the smell to what's dripping. There'd be no doubt at that point what it was.
tkruger
Reg: 07-19-18
09-17-20 12:21 PM - Post#2803667
No the question of what should be in the transmission? I am yet to open it up and change the fluids there. I am wondering is it may have been filled with 100+w gear oil or something and that is what is on my floor. It is thick like that. The oil I put in the engine (30w) flows far easier, hence the reason I suspect that it is not oil (but I have not pulled the cover to prove it). Joy of old cars that you do not know all of the history of.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
09-17-20 06:37 PM - Post#2803697
Might easily be 90 wt. gear oil in those old transmissions, but if you haven't changed it, then it might be too low to put a finger in and check the smell. But if it's thick, and gooey it's likely gear oil from the trans.
If the trans has to be removed to reseal it, it's not going to be a simple job. The enclosed driveline requires the rear axle to be unbolted and slid back before the trans can be removed for new seals. If it goes that far, then the trans should be closely inspected, and at the very least all new seals put in, even if the trans looks great inside.
Execution time: 0.088 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:34 AM
