Username Post: seat reinforcements?        (Topic#362581)
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
09-15-20 07:10 AM - Post#2803503
Hey all,
my seat is to squishy. I see a lot of people go to newer benches or buckets to correct this but I want my car to look and feel as original as possible inside. I was wondering if anyone has ever reinforced the springs or somehow "fixed" this problem. I am not overly large and neither is my wife. 150 and 135 respectively so its clearly a worn seat if it bothers us.
My only idea so for is to get a split bench from a modern car and basically make one solid seat from it and use high quality furniture foam to get the shape of the original, and then upholster it with the fabric from the old one. Seems like a lot of work; have to imagine there is a more direct fix...
open to ideas!
Drew
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
09-15-20 07:44 AM - Post#2803505
    In response to drew1987
Years ao I had the same problem with the seats in my Wagoneer, I had a friend in the upholstery business who did an easy fix using upholstery grade sting and tying the springs together, some of the original stuff had given up the ghost.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
09-15-20 08:30 AM - Post#2803506
You may wish to review this thread:
Also I am reupholtering the seat in my '53 6500. Aside from just coil springs, they installed a grid of spring steel wires sewn into bulap and hog ringed over the coil springs. Maybe "old school" but I like replicating what was there to begin with. Most of the original burlap had disintegrated, and the wires rusted...but there was enough there to figure it out. You can see it in the image laying on top of the springs.
Attachment: 1953_Chevrolet_Truck_Seat_Cushion_Dissection.jpeg (408.44 KB) 4 View(s)
1951 Fleetline Preservation
rawaag
rawaag
Loc: Williamsburg Virginia
Reg: 06-12-09
09-15-20 01:16 PM - Post#2803522
When I had the upholstery redone in my Chevy the front seat was like what you describe. The upholstery guy recommended having the springs retied and some heavy memory foam. It came out looking great and it's wearing well. I had it installed 8 years ago, and it shows no wear or sag. Good luck!
Ralph
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
09-15-20 02:22 PM - Post#2803525
    In response to rawaag
All the above is good advice. One thing more. They make "border wire" for the upholstery business as well as new "zig zag" springs.
The border wire is made of spring steel and will very effectively strengthen your springs when ised appropriately. Obviously, if any springs are broken they need to be repaired or replaced but that is common practice for any trimmer that knows his business.
Just Slightly Abrasive
drew1987
drew1987
Reg: 02-23-14
09-16-20 06:17 AM - Post#2803564
    In response to 40grit
Awesome thanks guys!
Member:
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
09-16-20 06:48 AM - Post#2803566
It is amazing what upholstery guys can do with sagging springs. When I had mine done I told the guy I wanted to feel like I was sitting on a pillow so he added lots of foam. It is very comfortable.
Attachment: 53_Chevy_front_seat.jpg (52.59 KB) 2 View(s)
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, EZ Wire, Vintage Air, Ididit column, Cruise/Tilt, PS, 59 Corvette Steering Wheel, 4-Wheel Discs, Posies Rear Springs, Coker Radials, Nova 10-bolt, Mustang II, NCA Continental Kit.
McCargar
Reg: 12-07-11
09-17-20 08:28 AM - Post#2803652
What I did for the sagging problem was to cut squares of foam and stuff the inside each springs. You can use a little or a lot depending on how hard you want the seat.
Execution time: 0.095 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:04 AM
