Username Post: HELP. 1962 Impala Powerglide shift linkage photos        (Topic#362577)
gdt3
Loc: Langley, BC
Reg: 12-22-14
09-14-20 04:11 PM - Post#2803485
Hi folks.
Can anyone help me out? I need photos of the column shift linkage for a 1962 Impala with a cast iron powerglide in it. From the column to the transmission and all the linkage at the transmission. There is also a linkage that goes from the carburetor to the transmission for kickdown. Any help would be appreciated. I've searched the internet until I'm blue.
Cheers,
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
09-14-20 06:23 PM - Post#2803487
    In response to gdt3
I have the linkage for a 62 cast iron power glide removed from a 62. It’s different than a 62 aluminum power glide linkage.
The bracket welded to the frame for the linkage is a cast iron PG only Bracket.
You have to find an original car for pictures on the car. Not many left in junk yards. Perhaps someone on this forum has one ( they were used behind 283 and 6 cylinder motors).
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
09-14-20 06:48 PM - Post#2803490
    In response to gdt3
The 62 assembly manual shows what you need in detail. The manual is available from many suppliers including Amazon and ebay.
Dave
gdt3
Loc: Langley, BC
Reg: 12-22-14
09-14-20 09:12 PM - Post#2803492
    In response to pvs409
Thanks. Mine is a cast iron that was behind a 283. Are you able to send pictures of what you have?
gdt3
Loc: Langley, BC
Reg: 12-22-14
09-14-20 09:13 PM - Post#2803493
    In response to dgstarr
Thanks for that. I'll have to check it out, if I don't have any luck here.
pvs409
pvs409
Reg: 01-10-05
09-14-20 09:59 PM - Post#2803495
    In response to gdt3
Later this week I can. Paul
gdt3
Loc: Langley, BC
Reg: 12-22-14
09-15-20 08:42 AM - Post#2803507
Thank you. What did you put in its place? I was going to put in a short TH350c but it is quite a bit longer than the short powerglide both in total length and where the mount sits. If it had been the long powerglide it should have been a bolt in. I decided to stick with the powerglide in order to get this car back on the road as quickly as possible. It's been sitting for far too long.
ragtp66
Reg: 12-09-07
09-17-20 09:59 PM - Post#2803713
    In response to gdt3
If Paul does not have what you need I may have most of it from a 61 283/Cast Iron Glide. I know I have the linkage from steering column to the frame mounted bracket, the passing gear bellcrank that mounts to the transmission/rear if engine. A couple more pieces of linkage.
Toys:
1987 Sea Ray Pachanga 22
pvs409
pvs409
Reg: 01-10-05
09-17-20 10:17 PM - Post#2803714
I have the frame bracket and the cast iron glide swivel that mounts to the frame bracket. and 2 other rods and the kickdown for the back of the motor.
pictures later Friday.
Execution time: 0.206 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:43 AM
