Username Post: 1962 wire help need a 12 volt while cranking for my PSI ls1 swap harness        (Topic#362573)
Alpine408
Reg: 08-06-20
09-14-20 12:48 PM - Post#2803466
Can someone tell me a good wire to tap that is switched on with ignition and stays on while cranking. Need it for my LS1 PSI wire harness. I read the instructions wrong and tapped the solenoid wire that loses power after cranking that will not work
Thanks guys
mlsully
Loc: Louisiana
Reg: 04-10-20
09-15-20 05:46 AM - Post#2803500
    In response to Alpine408
For my Holley EFI setup on my 62, I used the "Back-Up" spade on the fuse panel. That has power with key on and while cranking.
Execution time: 0.089 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:12 AM
