Danchuk
Username Post: Brake hose bracket        (Topic#362569)
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
09-13-20 06:44 PM - Post#2803423
What is the best way to repair a no longer useful front brake hose to brake line bracket?
Thanks.
Stan
Details - the bracket to hose fit is loose, wobbled out, the brake hose end that fits it was also rounded. I guess some minor reassembled the related hardware after the mechanic replaced the spindles. Any way, the driver side bracket has seen better days.
It's all good. Mostly
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
09-15-20 01:48 PM - Post#2803527
    In response to 4dr 57
It's been 2 days and no one has answered,
Surly others have seen this before,
The issue is the thickness of the bracket is just enough so when the brake line fitting is in the bracket a clip is pushed in and it holds the fitting in place preventing rotation or back and forth movement of the brake hose assembly.
Short of replacing or weld repair then filing to fit, is it possible to use shim material of some thickness bent "u" shaped and put through the bracket then install the brake hose?
Would that be tight enough?
Seems most any thing you would try would be in the way, or is it make another bracket and bolt, to the old bracket? Maybe machine screws.
Not really sure what I would do, maybe make another bracket and weld or bolt to old bracket?
VC56S 2 door Sedan, 40 Years
09-15-20 02:15 PM - Post#2803530
    In response to Bad56Sedan
Thats what I would do. Cut the old bracket off at the bend. Make and bend a new bracket that could be bolted to the top of the old bracket that is still on the frame. The old bracket and frame together, will be thick enough to drill and tap for a couple of bolts. Link to brake line bracket.
4dr 57
Reg: 11-10-04
09-20-20 03:48 PM - Post#2803912
    In response to acardon
I was told it is just a round hole, so trim and bolt or weld would be the way to go.
Silly me, I was expecting to be able to simply buy a couple of repair type brackets with the thickness obstacle in check.
I bought a hot rod fabrication bracket from Speedway and another stock bracket for a 67-69 Camaro as it looked long enough I could cut it and bolt or weld it to the original bracket.
we'll see how they look when they get here.
I would have thought that entire brackets would be common place. But they aren't. Weird.
A fabricator would be a good send!
A thin washer might be a solution or possibly even dimpling the horse shoe looking piece for a tighter fit.
Thanks.
Stan
4dr 57
Reg: 11-10-04
09-22-20 02:46 AM - Post#2804030
Well, the Detroit Inline Tube 68/69 Pontiac bracket arrived and it is almost a perfect bracket. I say almost because of course it does not look anything like the Tri 5 bracket, BUT, the bracket does have the perfect thickness and hole diameter, and the actual tab is long enough to work perfectly for this repair.
I have settled on using a machine screw to set it in place and will have a friend put a few spot welds to solidly connect it to the chassis, old bracket, frame, etc.
Thanks.
Stan
1956chevy
"3rd Year" Platinum Supporting Member
1956chevy
Loc: Orlando, FL .
Reg: 05-11-01
10-19-20 04:57 PM - Post#2805789
HI Stan. Do you have any photos of your install?
I have a similar problem. My 56 had an old disc setup on the front. I am replacing the whole system with a new CPP setup. The old disc setup had the calipers mounted on the front of the spindle, not the back. They had cut off and moved the original brake hose brackets. You can see in the photos how they modified them.
Like you I was amazed that you can not find a replacement bracket. I just ordered the Allstar ALL60029 thinking it will work.
I am interested in seeing how yours worked.
Thanks, Keith
Keith Marang
Webmaster
Central Oklahoma Classic Chevy Club
www.55-57chevys.com
4dr 57
Reg: 11-10-04
10-20-20 07:03 AM - Post#2805815
    In response to 1956chevy
Ok Keith, it's been a long time since I posted any pics - I'll give it a try - well I did ok. you will have to click url below the picture for a close up. I need to do a bit of touch up paint but here is area couple pic. Have Fun!
CPP- yeah!
The hose itself presented a fitment problem (chinese parts!) in that the gap in the end of the fitting where the U shaped thingie needs an added VERY thin washer with a big hole to fit over everything and close the gap. Perfect-
Lucky I had one. Come to think of it a .015- .020 piece of sheet or even brass would probably work too.
Perfect.
[image] https://i.ibb.co/s94mgMJ/IMG-3901.jpg[/image]
1956chevy
1956chevy
Loc: Orlando, FL .
Reg: 05-11-01
10-20-20 08:18 AM - Post#2805821
Stan, thanks for the photo. That is a good looking repair.
Keith Marang
Webmaster
www.55-57chevys.com
1956chevy
1956chevy
Loc: Orlando, FL .
Reg: 05-11-01
10-27-20 06:12 AM - Post#2806323
Stan, here is my completed install of the Allstar ALL60029 brackets. I am pleased with them. First I ground off the old bracket welds. Then I bent the new brackets to the correct specs.
I created templates for the 51 degree bend in each bracket, and the 26.5 degree mounting angle on the frame. (Can't help it ... used to be an Engineer.)
I should have cut off the old brackets in the wrong location, but I didn't want to make that big of a mess in my garage.
I was fortunate enough to have the original spot welds to position the new brackets in the correct location.
Thanks for posting the picture Stan.
Keith Marang
Webmaster
www.55-57chevys.com
Execution time: 0.167 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:35 PM
