Username Post: 65 big block water pump question        (Topic#362565)
995jim
995jim
Loc: Ohio
Reg: 12-17-06
09-13-20 05:52 PM - Post#2803413
Hello, Is the short hose which goes from the top of the water pump and the intake manifold necessary, if so what is its primary purpose? faster heat up? And does it actually take away cooling capacity because it forces coolant to bypass engine block.
thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
Oshawa65SS
Loc: Burnaby BC Canada
Reg: 09-22-14
09-13-20 08:01 PM - Post#2803425
    In response to 995jim
It's a BBC thing because their water pumps don't provide for an internal bypass like SBC.
It's mainly for water to circulate inside the engine while it's warming up to prevent hot spots and to let hot water circulate around the thermostat so it opens.
Ryan
Build date Dec. 21 '64 Oshawa
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
09-14-20 07:44 AM - Post#2803445
    In response to Oshawa65SS
Like Oshawa said. And its absolutely not necessary as long as you use a thermostat that has "bypass" holes in the flange. Those are easily available or you can drill 3 about 3/16 dia holes in it. I have 2 big block cars that I run that way and I have no temperature problems.
Execution time: 0.114 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:20 AM
