Username Post: EVAP Sytem        (Topic#362551)
Highlander1
Highlander1
Loc: SE North Carolina
Reg: 08-19-04
09-13-20 12:21 AM - Post#2803350
On 08-07-20 I made a post with the above subject. It seems to have never gotten posted. So, will give it another try.
On my 95 Caprice I recently discovered that some of the hoses to the EVAP canister were disconnected. This made sense as a couple of my passengers had said that they could smell gas fumes. I reconnected the hoses after replacing the smaller short one with new material. Then I also noticed a hose hose with what I will call a tee fitting (except I wonder if the smaller one is not a vent cor maybe broken off from something so far unseen) and and maybe a three inch section of hose that seems should be connecting to something. It has been suggested that it should be connected to a line coming from the fuel tank. The Haynes manual (P 6-19) has nothing about it except for a general (non specific) schematic.
Any thoughts on where my "loose end" should be going?
Thanks,
Execution time: 0.139 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:11 PM
