Username Post: Bench seat back        (Topic#362496)
chevydeluxe51
Reg: 08-28-20
09-08-20 02:24 PM - Post#2803034
51 2dr coupe. I noticed that my seat back on the drivers side is leaning back some. Is there any adjustment on the seat back itself to move it forward some? I didn't see any kind of a "stop" that would be adjusted as how far it leans back. Sure would help my back with a more upright position.
51chevcoupe
Gold Supporting Member
51chevcoupe
Loc: Washington state
Reg: 08-14-09
09-08-20 02:54 PM - Post#2803036
    In response to chevydeluxe51
I don't remember any adjustments (it's been 10 years) but I found that the metal fatigues and cracks sometimes, especially at the hole where it pivots, allowing the seat to start leaning back. The only way I know of to know for sure is to take the covering loose so you can get a look at the frame and mechanism.
Get some input from someone that has been into one more recent than me before you tear into it- it has been a long time since I messed with one of those seats.
Ed
1941 Master Deluxe 2 door sedan- 283/TH350
1950 Fleetline 2 Door project
1950 Styleline 4 Door sedan
1951 Ford Deluxe 4 door sedan- 302/AOD
Still confused after all these years!
52HardTop
Loc: North Haven, Connecticut
Reg: 05-09-04
09-08-20 04:59 PM - Post#2803051
There should have been a hard rubber stop on the seat base where the back would stop when it is in place. That would keep the metal of the back from sitting on the metal on the frame. I think that piece is probably near a half an inch thick? If it is missing, as you said you saw no stop, then that may be your problem?
2011 Camaro SS 426 HP, Red Jewel Tint. Killer!
52 Bel Air a traditional 50s Ride.
51 Convertible a 60s Ride.
51 1/2 Ton pickup soon to be a little of both..
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
09-08-20 05:58 PM - Post#2803056
    In response to 52HardTop
That is how I remember it.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
09-08-20 07:30 PM - Post#2803072
    In response to 2blu52
If you can wait until tomorrow I'll send you a picture
Airlifter
Airlifter
Reg: 06-07-15
09-09-20 03:30 AM - Post#2803084
    In response to Mike JW
Same problem with my'51 coupe. I have not been able to find the stops. If I can find some hard rubber I will try to make a set.
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
Edited by Airlifter on 09-09-20 03:30 AM. Reason for edit: No reason given.
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
09-09-20 06:57 AM - Post#2803099
Here's an old post that may be of help...:)
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, EZ Wire, Vintage Air, Ididit column, Cruise/Tilt, PS, 59 Corvette Steering Wheel, 4-Wheel Discs, Posies Rear Springs, Coker Radials, Nova 10-bolt, Mustang II, NCA Continental Kit.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
09-09-20 08:17 PM - Post#2803164
These are the inboard (2 center for left and right seat back) and the left outboard rubber bumper on a '51 2 Door front seat back.
1951 Fleetline Preservation
chevydeluxe51
Reg: 08-28-20
09-09-20 09:34 PM - Post#2803168
    In response to RAM_51
Will have to go look but I know that outboard one is not there.
chevydeluxe51
Reg: 08-28-20
09-10-20 08:54 PM - Post#2803234
I found some bulk hard plastic rod in 7/8 and 1". I also found 5/8 hard rubber round in lengths. I guess I'll try and make some. It doesn't look that hard to do and it's not critical any way.
RAM_51
RAM_51
Reg: 12-28-02
09-11-20 05:35 AM - Post#2803242
Steele Rubber does sell various types...this one comes closest from the image anyway.
LINK:
https://www.steelerubber.com/folding-seat-bumper-7 ...
Execution time: 0.129 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:16 AM
