Username Post: Vacuum advance 327        (Topic#362479)
bolake
Loc: Northern MN
Reg: 09-05-17
09-07-20 02:43 PM - Post#2802948
Been looking over 55 chevy belair with 327 I just bought. Starts and runs good but noticed the vacuum advance on distributor , the tube that runs to carburetor has been purposely disconnected from carburetor, and the fitting in carb has a rubber plug cap on it. Anyone have insight for doing this?
If your not the lead dog the view never changes
09-07-20 04:31 PM - Post#2802951
    In response to bolake
The vacuum advance pot may be leaking and that was a quick fix. No reason that I know of to disconnect it on a street driven car. Check that it holds vacuum.
Edited by acardon on 09-07-20 04:32 PM. Reason for edit: No reason given.
bolake
Loc: Northern MN
Reg: 09-05-17
09-08-20 05:00 AM - Post#2802984
    In response to acardon
Pumped it up to 15" let it set for 15 seconds, didn't leak. Guess I will hook it up and see what happens Thanks
Edited by bolake on 09-08-20 07:01 AM. Reason for edit: No reason given.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
09-08-20 06:59 AM - Post#2802991
Recommended reading:
https://www.chevelles.com/threads/ignition-101.189...
The 'amount' of advance? At idle, initial timing plus vacuum advance
is best at approx 22-24 degrees BTDC. Vacuum advance connected to 'full manifold' (the carb port that's below the throttle plates).
Initial timing (w/o vacuum advance) around 12, and vacuum advance around 10-12 works very well. Recommend trying a few different combinations to determine the 'best' settings.
Your cam will determine the amount of 'vacuum' you have available. Adjustable (for 'vacuum') advance 'cans' are available.
Pete
Edited by japete92 on 09-08-20 07:00 AM. Reason for edit: No reason given.
bolake
Loc: Northern MN
Reg: 09-05-17
09-08-20 07:04 AM - Post#2802992
    In response to japete92
Thanks for information, Was trying to figure why it was purposely unhooked from carburetor, Put the vacuum on it pressure holds. Will hook it up and see what happens.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
09-08-20 08:09 AM - Post#2803000
Maybe from the last time they set the timing, and forgot to hook it back up.
bolake
Loc: Northern MN
Reg: 09-05-17
09-08-20 09:26 AM - Post#2803010
    In response to 55 Shaker
Could be, will hook it up later and start it up, see what happens. Plugged it into the carburetor port. Runs, idles fine, just a hair faster idle then when its unplugged. Seems if they had forgot to plug it in after timing they wouldn't of put a rubber cap on the carburetor port.
Edited by bolake on 09-08-20 02:34 PM. Reason for edit: No reason given.
bolake
Loc: Northern MN
Reg: 09-05-17
09-08-20 04:17 PM - Post#2803046
After reading your information from GM engineer about vacuum, 2 things come to mind on my engine. (1) I'm wondering if the vacuum line was left off the vacuum port on carb & plugged to help cool idle temperature. (2) The car has front disc brakes conversion with the dual master cylinder with booster and by plugging the carb port would help with more vacuum for the booster.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
09-09-20 06:38 AM - Post#2803095
Here's more info:
http://www.superchevy.com/how-to/additional-tec h/1...
Was/is the engine set up/built for racing only?
Question 1: Timing does impact temps, BUT the only reason to not have vacuum advance is if the engine is only being asked to perform at high rpm; basically at wide open throttle.
Q2: More likely it's plugged to simply eliminate the vacuum leakage 'unplugged' would cause. BUT, if the cam installed is long duration with a short separation angle it is suited for high-rpm drag racing, with a high-end, sharp torque peak. Manifold vacuum will be very low to non-existent. Plugging that carb port won't change that.
If you have nothing better to do, here's some cam shaft info:
Why did a previous owner do what he did? No clue. If this engine is planned for street driving, it needs vacuum advance.
I've attached some tid-bits about vacuum advance.
Just trying to be helpful.
Pete
Attachment: vacuum_advance_READ_FIRST_overview.pdf (129.42 KB) 10 View(s)
Edited by japete92 on 09-09-20 10:56 AM. Reason for edit: No reason given.
09-09-20 06:42 AM - Post#2803096
You have to plug the carb port to set timing or you will have a vacuum leak. The vacuum advance pot doesn't use any vacuum unless the manifold vacuum changes, and then it's so little, it will not affect the booster. The vacuum advance is a closed system, unlike the booster and PVC systems, which have to replinish the vacuum when operated.
Member #409
09-09-20 09:48 AM - Post#2803110
Retarded timing produces heat in the coolant.
Advanced timing puts less heat in the coolant.
So you want the vacuum advance hooked up.
IgnitionMan
Reg: 04-15-05
09-09-20 10:58 AM - Post#2803114
I see a lot of "disconnect the vacuum advance, it doesn't do nothin'" all the time on the tech boards, total hot air from all sorts of supposed tuners that literally refuse to understand vacuum advance.
NOT hard to get the vacuum advance set up right, then use it to supplement idle and no load cruise, on full manifold vacuum, and to use a stop to set the total degrees the advance gives when plugged in.
Most people I see posting on timing issues and problems have no idea how to set a vacuum advance up to work right, let alone connect it to the full manifold vacuum fitting.
One very good vacuum advance information source is a whole package, lets you get it done right, that I send out to everyone for free.
Easy way to get the whole package, ask for it at this email address,
gmvacuumadvancemodificati ons@gmail.com
bolake
Loc: Northern MN
Reg: 09-05-17
09-09-20 12:43 PM - Post#2803122
Pretty sure not setup for racing. Put the gauge on the vacuum port on carburetor, idling at 13. Notice when I hook up vacuum I have slightly higher idle, maybe 100 rpm's. Just took it for a 5 mile run seem to run good. Will do some experimenting. Thanks to all for the information.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
09-09-20 01:24 PM - Post#2803127
The attachment I posted earlier came from "Ignitionman' . He sent it (and other data) to me in response to an email request I sent him to the address he posted. He sent it totally free; no adds. Recommend the info.
AND, just to make sure we are communicating, ALL the 'numbers' I posted were timing 'degrees' BTDC.
Pete
bolake
Loc: Northern MN
Reg: 09-05-17
09-09-20 02:27 PM - Post#2803130
OK Thanks I have already got the info from him
Execution time: 1.469 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:14 AM
