Username Post: daytime running lights        (Topic#362400)
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
08-31-20 07:17 AM - Post#2802376
Cant get my daytime running lights to work.
One went out a few months ago, then the other.
Put new bulbs in and checked the fuse.
Any suggestions ?
2001 siverado
1950 Chevy Styleline Deluxe 235
nstlga
nstlga
Loc: Colorado
Reg: 12-01-05
08-31-20 09:39 AM - Post#2802405
    In response to Larry E
Long time wide spread problem. The sockets themselves are probably bad. It's from too much heat generated by the bulbs. I had trouble with my '04 when still under warranty, they changed the sockets. No problems since, but I shut them off most of the time.
He who dies with the most toys doesn't necessarily win, but had more fun getting to the finish line.
Smitty_Chevy
Smitty_Chevy
Loc: Hampton, GA
Reg: 10-29-08
09-06-20 08:40 AM - Post#2802884
Are you sure they're not working? If you have your truck in park when you're checking the running lights they won't be on. If you put on the parking brake they also won't be on. Have someone check while you have it in drive or put a scotch under the wheels to check while it's in gear.
The tree of liberty must be refreshed from time to time by the blood of patriots and tyrants - Thomas Jefferson
Edited by Smitty_Chevy on 09-06-20 08:41 AM. Reason for edit: No reason given.
Senior Moderator
09-06-20 09:48 AM - Post#2802886
    In response to Smitty_Chevy
I'm familiar with the parking brake turning off DRL's on the later GMT400 trucks (96-up) but on my 06 the parking brake has no effect. I used it to check my LED replacement bulbs in the DRL's. Truck in neutral, parking brake set.
Be sure your parking brake works before trying this, by the way, especially if you have rear disc...many do not work very well at all!
Smitty_Chevy
Smitty_Chevy
Loc: Hampton, GA
Reg: 10-29-08
09-15-20 11:48 PM - Post#2803551
    In response to someotherguy
My 2003 the running lights go out when the emergency brake is on.
I have to have someone hold the brake or I put a scotch under under a tire.
Site Ambassador
09-16-20 02:57 PM - Post#2803600
My DRLs haven’t worked since I bought my truck (‘99 NBS), but my auto lights stay out if the parking brake is on when I start the truck and come on when I release it. They do not go back out if you reapply the parking brake. Do the DRLs go out any time you apply the parking brake?
1957 Cameo Carrier
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
09-19-20 05:30 AM - Post#2803791
    In response to wagonman100
I have noticed problems with my DRLs (2006 GMC Sierra 1500). I've replaced bulbs and got them working, but noticed the connectors have gotten pretty warm.
Is there a LED bulb solution for these lights? I seem to remember someone trying this LED replacement and the bulbs wouldn't illuminate.
Thanks,
HandyAndy
Senior Moderator
09-19-20 07:22 AM - Post#2803798
    In response to HandyAndy
Thanks,
There are LED's that are intended for use as DRL's; helps to find them if you search by the regular DRL bulb # of 4114 for your 2006 Silverado (I've got the same year/model.)
I chose some under the brand name "Partsam" that I found on amazon. They were cheap enough to gamble, about $11 for the pair, and they work fine. I was doing a lot of daytime driving at the time and they lasted about a year before some of the LED's on them began to fail, which is kind of common on these cheap LED replacements (and even on some of the expensive ones.) Instead of worrying too much about it, I just bought another pair of the same.
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
09-20-20 07:30 AM - Post#2803865
Thanks for the information. Yesterday, I checked my DRLs and found them both working! I attempted to pull the bulb on the passenger side but, the bulb has melted the socket and it's stuck. Most likely I'll break the bulb getting it out of the socket.
It must be time to upgrade the sockets and install LEDs.....
Thanks again,
HandyAndy
Execution time: 0.101 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:16 AM
