Username Post: 57 front end lean        (Topic#362340)
Mdm57
Reg: 12-17-18
08-26-20 02:27 PM - Post#2802029
totally rebuilt the front suspension on my 57 sedan----shocks ---control arms--springs--ect but drivers side front is still three quarters of an inch lower than the pass side---measuring at the wheel wells--the rear is even side to side everything looks normal all gaps normal .nothing bent. doesnt look like its ever been in a wreck body mounts dont look that great. could that be the cause of the lean
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
08-26-20 04:16 PM - Post#2802036
    In response to Mdm57
Did it lean before the front end rebuild?
Is the upper coil of the springs really seated in the frame?
Maybe one isn't?
Which side has the issue?
How do you tell?
It is possible to raise the front end, get one tire just off the floor, is the other one the same?
Raise both front tires just off the ground by using a floor jack under the front crossmember in the center, then measure under the frame to the floor about where the original motor mounts are and the front frame horns to the ground, if all the same it really should not be the frame,
Now you Lower the car back down which tire hits the floor first,
Measure and make a judgement.
Surely the ball joints are the same on both sides?
Not sure what else to ask, surely the springs are the same?
VC56S 2 door Sedan, 40 Years
08-26-20 04:47 PM - Post#2802038
That would be my first suspect, either in the frame pocket or the lower control arm. See Note about "stop": Link to spring pocket.
Mdm57
Reg: 12-17-18
08-27-20 10:47 AM - Post#2802085
    In response to acardon
If every thing is in place would a 1 inch spring spacer raise it up
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
08-27-20 08:47 PM - Post#2802138
Don't forget about possible uneven rear springs.
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
09-07-20 02:39 PM - Post#2802947
Was it repairable?
What was found?
Execution time: 0.168 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:25 AM
