Username Post: DeWitt aluminum radiators        (Topic#362336)
SteveW
Loc: Shreveport
Reg: 04-24-02
08-26-20 02:24 AM - Post#2801997
Has anybody bought and tried DeWitt aluminum radiators ? The cost seems high but if they are as good as they say about cooling I may try them. They say that their radiator features two rows of one inch wide tubes and will provide 30% more cooling than an equal size four-row copper radiator. Any information on them would be great. Thanks . Steve
SteveW
Edited by SteveW on 08-26-20 02:30 AM. Reason for edit: No reason given.
jdk
jdk
Loc: columbus, ohio
Reg: 02-15-10
08-26-20 06:29 AM - Post#2802006
    In response to SteveW
i have one in my 63 vette. it works great. dewitt
has sold the business and has retired. but he says
every thing is the same. jim
Blown1100
Loc: Weatherford,Texas
Reg: 05-11-03
08-26-20 05:08 PM - Post#2802042
    In response to jdk
A friend had a 56 car and 56 big block truck both running hot in Texas weather. Installed Cold Case in both and fixed the problems.They are not cheap but great quality. Loy
Member #409
08-27-20 09:29 AM - Post#2802079
Not familiar with DeWitt but there are many crossflow aluminum radiators out there with similar construction. As long as the fabricated tanks are fully tig welded they make a fine radiator that lasts a long time and cools extremely well if you use a quality fan setup too.
Most if not all of the custom radiators use cores from a limited number of sources.
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
08-28-20 11:41 AM - Post#2802167
Living in Texas I wouldn't buy any radiator unless it had 1.25" tubes.
My two row radiator with these spec'd tubes cools my 350 / 11:1 engine (aluminum heads) just fine.
It's all good. mostly
Execution time: 0.109 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:59 AM
