Username Post: Vibration        (Topic#362263)
tooomuch7
tooomuch7
Loc: Hartford Ohio
Reg: 03-18-02
08-19-20 05:20 PM - Post#2801535
Hi guys,took the 57 out today,.it has one heck of a vibration in it when you are on the gas pedal,let off the gas it stops,hit the gas and it’s back,so basically it’s doing this when under power,now the other part is if your off the gas and coasting and you push the clutch in it starts the vibration again,let the clutch out while coasting it goes away. Then hit the gas it starts vibrating again,I have some ideas,but thought I would ask here to see if I’m on the right path.Any Thoughts on this?
http://www.picturetrail.com/gallery/view?p=999&gid=5387542&uid=2695815&members=1
08-19-20 05:52 PM - Post#2801536
    In response to tooomuch7
Motor mounts and then U-joints.
tooomuch7
tooomuch7
Loc: Hartford Ohio
Reg: 03-18-02
08-20-20 02:50 AM - Post#2801551
    In response to acardon
The first thing I thought of was u-joints,but the part I don’t understand is when your coasting and you push the clutch in it starts the vibration again then let the clutch out while still coasting and it quits. I will definitely look at those two things.
Execution time: 0.121 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:51 AM
