Username Post: Vin Tag On A Pillar Fasteners        (Topic#362252)
Dustythedog
Dustythedog
Loc: Niagara Falls NY
Reg: 08-10-08
08-19-20 11:11 AM - Post#2801498
Hi Guys, I have a 57 made in Flint. The vin tag on the A pillar in screwed on. Is this correct? I thought all were spot welded or installed with drive rivets.The data plate on the firewall looks normal.It looks like the tag was removed for repainting. My goal is to put it on the way the factory did it.Anyone familiar with this?
Thanks, Russ
08-19-20 11:39 AM - Post#2801502
    In response to Dustythedog
Only the exported knock-down cars had a riveted VIN tag. All others were welded. Link to VIN.
Dustythedog
Dustythedog
Reg: 08-10-08
08-19-20 07:58 PM - Post#2801545
    In response to acardon
Thanks Don. Very helpful.
elcamino
elcamino
Reg: 03-30-00
08-20-20 07:54 AM - Post#2801566
Integrity of a VIN – The Key to Identifying a Vehicle & Preserving Your Investment
2017 GMC Sierra Denali Ultimate 6.2L / 8-sp Z95
2018 Polaris RZR S 900 EPS
56 wagon gasser
Reg: 09-28-11
08-23-20 05:11 PM - Post#2801819
    In response to elcamino
Since his is screwed on and it suppose to be welded, how do you correct this?? Is the welding something that can be done at home?? Thank.
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
08-23-20 06:38 PM - Post#2801822
    In response to 56 wagon gasser
verify the serial numbers on the screwed on vin tag with the frame numbers,
if the are the same, leave it alone
if not, sounds like a topic for another post
VC56S 2 door Sedan, 40 Years
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
08-23-20 09:33 PM - Post#2801831
The problem is usually one thing or another; the tags get removed for painting, or the welds holding them on get rusty, or the body metal gets rusty, and then the plate falls off. The tags are stainless steel, the body is carbon steel; dissimilar metals don't weld together very well, and when rust sets in, one day you find you're missing your tag. Corvettes had them screwed on, and like someone else said, export cars were different also (I'm taking them for their word on that). If your car ever gets inspected, it will cause an issue you don't want to deal with. Confirm your frame number with the tag, although the frame number is not the complete VIN. It's located on top on the drivers side frame rail in two spots along the general area of the front seat. If the frame number "matches" the VIN tag, it can be welded back on, but it may be hard finding someone willing to do it; probably TIG with wet rags to save the paint. It's still not going to look like the stock spot weld (since the tag has holes in it now), and that may trigger an issue also if it's ever inspected. Or just leave it alone, and let the next owner mess with it. There's always your DMV to get ahead of it before there's a problem. I am Butch/56sedandelivery.
Execution time: 0.124 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:05 PM
