Username Post: 57 Westclox Dash Clock        (Topic#362070)
canuck57
"19th Year" Silver Supporting Member
canuck57
Loc: Campbell River,B.C., Cana...
Reg: 11-06-02
08-07-20 01:20 PM - Post#2800547
Anybody know what the tiny threaded stem and nut are on back of clock, photo attached
Attachment: 3ADCA2CA-27D7-4136-9333-F20040625D13.png (4.54 MB) 45 View(s)
Someday,I'll be ridin' in a 57 chevrolet,she'll have whitewalls,headlights like diamonds,someday, someday.......
Edited by canuck57 on 08-07-20 02:05 PM. Reason for edit: No reason given.
Beltfed
Reg: 10-04-18
08-08-20 01:11 PM - Post#2800622
    In response to canuck57
The one with the orange gasket is +12 volts in. The stem is fast/slow adjustment.
This clock like others works by closing an internal set of contacts. When closed the voltage energizes an electromagnet which is thrown in a semi circular fashion. This “cocks” the magnet and opens the contacts. A spring slowly pulls the magnet back to its ‘resting’ position. The clock then operates by energy built up in the spring being put into expansion by the magnets movement. And so on.
The gap of the points is critical as is the condition of the points as upon closure the points see almost a dead short.
canuck57
canuck57
Reg: 11-06-02
08-08-20 03:30 PM - Post#2800628
    In response to Beltfed
Thanks, is the fast/slow stem adjustable with screwdriver or ??
08-08-20 04:04 PM - Post#2800630
I don't think there is a external fast slow adjustment. I understood that by repeatedly adjusting the clock in the same direction, it would adjust itself.
Beltfed
Reg: 10-04-18
08-09-20 06:14 PM - Post#2800731
    In response to acardon
I agree. I’m probably wrong on the tab being the fast/slow adjustment. It’s be a while since I torn one apart. My second guess is the ground wire to the electromagnet coil. The clock ‘guts’ come out as a unit so the ground wire needs to have a way to disconnect from the housing.
Execution time: 0.736 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:28 PM
