Username Post: Replacement Speedometer        (Topic#361971)
jimbob0464
Reg: 07-17-19
07-31-20 10:57 AM - Post#2799995
I have a 1954 3100 truck. I got a new (replica) speedometer. I installed it and now the speedometer does not work but the odometer does. Aside from the dash lights, is there any power that needs to be hooked up to the speedometer? I did not see anything when I took the old one out. As this is a brand new speedometer I think all I should do is hook up the cable. Since the odometer works I am thinking I did. Any suggestions?
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
07-31-20 11:14 AM - Post#2799997
    In response to jimbob0464
The entire speedometer / odometer is mechanical. There is a direct mechanical connection (series of gears) that operated the odometer...but NOT a direct mechanical connection to the speedometer needle.
It works by means of a rotating magnet inside of a drum that also has a magnet in it. Each time the rotating magnet passes the magnet in the drum, it pulls the drum with needle attached, away from ZERO. A very delicate "clock type" spring returns the needle to the zero position. The spring also aids in smoothing out the operation of the needle.
It is my guess that the drum or spring or both are damaged, or not hooked up correctly. This is actually the most delicate part of the speedometer. Once the speedometer is removed from it's case, you should be able to look behind the face plate to inspect the drum and spring mechanism. If it arrived in this condition, it may be best to contact the seller to work something out to get a replacement.
1951 Fleetline Preservation
jimbob0464
Reg: 07-17-19
07-31-20 11:25 AM - Post#2799998
    In response to RAM_51
So either I got a defective speedometer (possible) or I somehow did not hook it up right( just as possible as it is the first time i ever did that).
How tight should the cable be? Just hand tight or more. I just did it hand tight.
RAM_51
RAM_51
Reg: 12-28-02
07-31-20 11:30 AM - Post#2799999
There is just one connection and that is the cable into the rear of the case. Hand tight is about all that is needed. If the odometer is working, it is hooked up properly. My guess is something is defective with the drum, magnets, spring, or even connection between the shaft and the needle. Is there even the slightest amount of movement of the needle or none?
jimbob0464
Reg: 07-17-19
07-31-20 04:33 PM - Post#2800030
There is no movement in the truck. However, I took it out and used a power tool and spun it and the needle did go up and down when I did that. I put it back in the truck and nothing. The end of the cable seemed like it was starting to spread apart like a power wire. So I'm thinking I need to replace the cable.
Edited by jimbob0464 on 07-31-20 04:35 PM. Reason for edit: No reason given.
RAM_51
RAM_51
Reg: 12-28-02
07-31-20 08:08 PM - Post#2800043
Try that. The cable should have a nice square end on it. I certainly do not understand how the odometer could be advancing and the needle not moving though.
BAJohnny
Loc: Kentucky
Reg: 04-04-13
07-31-20 08:10 PM - Post#2800045
Did the old speedometer work? Could be the gears inside the trans.
1953 BelAir 2dr Sedan
1953 BelAir 2dr Hardtop
jimbob0464
Reg: 07-17-19
08-01-20 07:11 AM - Post#2800062
So, Going home last night the speedometer did work, kinda. It went up to 50mph when I was on the HWY and slowly went down to 40 even though I was doing 65. When I got off the HWY it went down to 20 and did not move after that. How far in does the cable have to go into the speedometer and would a frayed end cause it to act this way?
08-01-20 08:34 AM - Post#2800072
Did you know '54 to (about) '59 Chevy school busses used the same gauge set and speedo that the '54 and 1st series '55 pickups used. The '55 to roughly '59 school busses were also 12V, so the water temp is 12V electrical instead of mechanical, and the gas gauge is 12V also.
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
08-01-20 09:01 AM - Post#2800075
Since the speedometer and the odometer are working to some extent then the problem lies in the speedometer and not in the cable.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
RAM_51
RAM_51
Reg: 12-28-02
08-01-20 09:11 AM - Post#2800076
If there is not a positive connection between the cable and the speedometer, the cable can conceivably spin faster than the receptacle in the speedometer...sort of a the way a clutch does when it is being engaged. The cable on my '53 protrudes approx 1/2" beyond the seating cup and is decidedly square.
Attachment: 1953_6500_Speedometer_Cable_-_Gauge_End..jpeg (2.48 MB) 2 View(s)
junky
Loc: Northeast CT
Reg: 06-27-10
08-02-20 11:37 AM - Post#2800148
Disconnect the speedometer cable, and try to turn it from the speedometer head. If you can turn it, then the problem lies in the transmission. If you can't, then it is at the top end. I would pull the cable out of the sheath, and check it for damage (broken wire) by running it between a cotton cloth as if you were wiping it dry. If it snags, then it is defective and should be replaced. Do it in both directions. Also, if the cable doesn't protrude like in the picture above, then it might have been replaced at one time with one that is too short. The other think is the the square end might not be correct for your speedometer, or it might be worn enough to be slipping in the speedometer head.
Execution time: 1.821 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:25 PM
