Faulty Logic
Loc: Cleveland,Ohio
Reg: 07-27-12
07-30-20 04:40 PM - Post#2799947
Greetings all,my Vega stalls when I put it in gear?Stock motor,trans,convertor,vac uum advance is working.NEVER had trouble like this before.Anybody know whats wrong here?Thanks
08-02-20 10:03 AM - Post#2800140
In response to Faulty Logic
v8?
Faulty Logic
Loc: Cleveland,Ohio
Reg: 07-27-12
09-03-20 02:50 PM - Post#2802666
In response to bobb
Hello,yes I put in a V8 350 engine and 350 Turbo.When I start the car it runs fine.When I put the car in ANY gear WITH MY FOOT OFF THE BRAKE the wheels turn in both directions (REVERSE-DRIVE).As soon as I hit the brake,it stalls.Ive been told that maybe the trans is damaged internally and Drive and Reverse gears are Locked at the same time causing the problem.How could the trans function in BOTH DRIVE and REVERSE if that was the problem?Ever seen this problem before?What do you think?Thanks
Site Ambassador
10-03-20 06:27 PM - Post#2804764
Are you saying that with the rear wheels raised and the car in gear one wheel rotates forward and one rotates backward? If you don’t have a positraction rear, that is normal. As far as the stalling goes, you could have an internal leak in the brake booster. Try disconnecting and plugging the line going to the booster, start the car and apply the brakes and see if it still stalls. It would actually be best to plug the fitting in the manifold for the power brakes as the leak could be in the hose. But either way, the vacuum draw will not be increased by applying the brakes, so the engine shouldn’t stall from doing that.
1957 Cameo Carrier |
56sedandelivery
Deceased Member RIP
Loc: Everett, Wa.
Reg: 02-26-08
12-31-20 11:33 AM - Post#2811065
In response to wagonman100
There's actually a way to have an automatic transmission in both a forward AND reverse gear at the same time; it's called a trans-brake used for drag racing. It's used to lock the car on the start line, bring the engine speed up against the torque converter, and when the trans-brake switch is released, it's in low gear and reverse is "dumped". And off you go. Almost like dumping the clutch in a manual trans car. But, I don't think that's your probably as you probably don't have a trans-brake. As far as your issue goes, my guess is carburation VS timing VS vacuum or vacuum leak. If you're not sure about your trans, drop the pan and look for metalic particles or bits. If it's a NEW trans, maybe the sprag was put in backwards?
I am Butch/56sedandelivery.
Algoma56
Reg: 03-14-05
06-15-21 07:20 AM - Post#2821624
Do you have a Turbo 350 with lock up convertor? If the circuitry failed, then braking can cause it to stall. I know this has happened with the later transmissions with lockup systems.
Texasray
Reg: 11-01-16
08-03-21 10:35 AM - Post#2824391
In response to Algoma56
This would be my thought also. If you installed a turbo 350C then check the lockup circuit function to make sure it is disengaging the lock up solenoid in the trans. I think the brake switch interrupts the 12v signal, then there is a minimum pressure switch in the valve body. I believe the switch is normally open with no or lower than spec pressure. If that checks good then it could still be that hydraulic circuit not dumping pressure. There's a check ball involved if I remember correctly.
If it is not a 350C, then never mind!
Sam
65_Impala
Reg: 12-29-02
09-21-21 12:15 PM - Post#2827606
Vacuum booster leaking?
