Username Post: V8 Vega Hates me        (Topic#361966)
Faulty Logic
Loc: Cleveland,Ohio
Reg: 07-27-12
07-30-20 03:40 PM - Post#2799947
Greetings all,my Vega stalls when I put it in gear?Stock motor,trans,convertor,vac uum advance is working.NEVER had trouble like this before.Anybody know whats wrong here?Thanks
08-02-20 09:03 AM - Post#2800140
    In response to Faulty Logic
v8?
Faulty Logic
Loc: Cleveland,Ohio
Reg: 07-27-12
09-03-20 01:50 PM - Post#2802666
    In response to bobb
Hello,yes I put in a V8 350 engine and 350 Turbo.When I start the car it runs fine.When I put the car in ANY gear WITH MY FOOT OFF THE BRAKE the wheels turn in both directions (REVERSE-DRIVE).As soon as I hit the brake,it stalls.Ive been told that maybe the trans is damaged internally and Drive and Reverse gears are Locked at the same time causing the problem.How could the trans function in BOTH DRIVE and REVERSE if that was the problem?Ever seen this problem before?What do you think?Thanks
Site Ambassador
10-03-20 05:27 PM - Post#2804764
Are you saying that with the rear wheels raised and the car in gear one wheel rotates forward and one rotates backward? If you don’t have a positraction rear, that is normal. As far as the stalling goes, you could have an internal leak in the brake booster. Try disconnecting and plugging the line going to the booster, start the car and apply the brakes and see if it still stalls. It would actually be best to plug the fitting in the manifold for the power brakes as the leak could be in the hose. But either way, the vacuum draw will not be increased by applying the brakes, so the engine shouldn’t stall from doing that.
1957 Cameo Carrier
Execution time: 0.241 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:48 PM
