Username Post: Header tube "Thickness"        (Topic#361927)
Zoomy
Zoomy
Loc: Virginia
Reg: 04-04-03
07-27-20 08:26 AM - Post#2799668
I'm looking at a set of headers for my '72 Chevelle SB from OPG. I have the option of 16 or 18 gauge primary tubes. If everything else is equal, wouldn't 16 gauge be better ?
'72 Chevelle (2rd & 4th owner)
07-28-20 07:10 AM - Post#2799737
    In response to Zoomy
the 16 should last longer and sound quieter.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
07-28-20 08:03 AM - Post#2799752
    In response to bobb
keep in mind ceramic coating helps increase the header durability, and tends to reduce rust , and remember heat and cooling off in moisture is the thing that is causing most wear, heat is related to the fuel/air ratio and ignition timing , if the engine runs lean or the timings retarded exhaust heat tends to increase.
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
08-05-20 12:24 PM - Post#2800382
    In response to grumpyvette
The smaller the gauge # the thicker the metal.
16 gauge is .060 thick
18 gauge is .048 thick
Execution time: 0.174 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:25 PM
