Username Post: 62 generator mounting bolts        (Topic#361922)
rdweddle
Reg: 07-05-20
07-27-20 06:22 AM - Post#2799646
Having trouble with finding correct bolts for mounting generator. I purchased a parts catalog and the bolt #'s in the assembly manual are not listed in the catalog.
Highlander1
Highlander1
Loc: SE North Carolina
Reg: 08-19-04
07-27-20 07:36 PM - Post#2799707
    In response to rdweddle
RD, you are going to have to help us out a little.
For starters (no pun intended) please give us the year, make, model and engine description. Then more detail such as what the bolts attach to. And, what often helps is a photograph or two.
Regards,
rdweddle
Reg: 07-05-20
07-28-20 05:43 AM - Post#2799727
    In response to Highlander1
62 Impala 327 300hp. generator. Trying to find correct size bolts that attach the generator to the bracket?
junky
Loc: Northeast CT
Reg: 06-27-10
07-28-20 08:27 AM - Post#2799744
62 Impala 327 300hp used an alternator, not a generator. Two different type mountings for the generator vs. alternator. A 3rd type was the 62 amp alternator, which used a cast iron mounting bracket. It is important to use current day terms when describing a part. In 1962 GM did refer to this as a generator, however, later on they described it as an alternator. If you went into the auto parts store and asked for a 1962 generator, you would get a generator, not an alternator. Now, specifically, what do you have?
del.impala
Loc: delaware
Reg: 04-13-11
07-28-20 08:50 AM - Post#2799748
    In response to junky
Junky, my late Dec. 1961 impala 327/300hp motor came with and still has the OE generator.
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
07-28-20 08:55 AM - Post#2799750
Weren't all alternators optional in 1962?
junky
Loc: Northeast CT
Reg: 06-27-10
07-28-20 09:54 AM - Post#2799755
    In response to del.impala
What is the part number and date code stamped into the Delco ID tag??
Highlander1
Highlander1
Reg: 08-19-04
07-28-20 10:44 AM - Post#2799759
    In response to 55Brodie
Its been my understanding that there was a roughly mid year change over from a generator to an altenator for 1962 and that this altenator continued to be called a generator. The exact timing of the changeover varied among plants.
Verne_Frantz
Member #574 "61-64 Subject Matter Expert"
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
07-28-20 02:08 PM - Post#2799775
To clear up the '62 alternator debate, The alternator (or AC generator, as Chevy called it) was optional with any engine except the 409. It was included as standard equipment with all engines when ordered with Air Conditioning.
Verne
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
07-28-20 04:56 PM - Post#2799790
    In response to Verne_Frantz
Very interesting. Was the name "AC" for alternating current or "AC" for air conditioning in the name for "AC generator"?
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
Proud member of Big Blue Nation, University of Kentucky Basketball. "Go Big Blue"
Edited by kingkreeton on 07-28-20 04:56 PM. Reason for edit: No reason given.
Verne_Frantz
Verne_Frantz
Reg: 08-22-00
07-28-20 07:33 PM - Post#2799807
    In response to kingkreeton
Electrical. AC vs DC.
Verne
Even a nitwit will occasionally stumble over the truth, but most of the time he will pick himself up and carry on as if nothing happened.
rdweddle
Reg: 07-05-20
07-31-20 06:26 AM - Post#2799979
I will check, my father says it's a generator. It has a a metal bracket that it bolts to.
rdweddle
Reg: 07-05-20
07-31-20 11:52 AM - Post#2800001
The first few digits are not very legible, but the last four are 2097. I think it may be 7302097.
Verne_Frantz
Verne_Frantz
Reg: 08-22-00
07-31-20 01:22 PM - Post#2800013
The 097 is the std generator.
Unfortunately, I do not have any good photos of the original bolts. I neglected to document them when I put mine together recently. One of the nuts is a swagged lock nut that doesn't use a lock washer. I'll have to check around and see if I have any extras.
Verne
rdweddle
Reg: 07-05-20
08-01-20 05:51 AM - Post#2800057
As far as the bushings. There is only 1?
Verne_Frantz
Verne_Frantz
Reg: 08-22-00
08-01-20 06:07 AM - Post#2800058
The rubber bushing is on the front end frame only.
Verne
Execution time: 0.224 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:39 PM
